[gdal-dev] GDAL WMTS get tiles no documentation
Michał Kowalczuk
michkowalczuk at gmail.com
Fri May 31 06:31:51 PDT 2024
Thank you Rukka,
Since *-srcwin* and *-projwin* are options only for *gdal_translate*
utility, your suggestion leads me to use *GDALTranslate()* function with
these parameters.
This means that I cannot use directly created WMTS dataset to retrieve data
(using GDALDatasetRasterIO), but create a new (in-memory or file-based) for
each map extent change.
And this is the standard way of doing it?
Do I understand it correctly?
Michal
pt., 31 maj 2024 o 15:13 Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
napisał(a):
> Hi,
> Before starting to program you can familiar yourself with the topic by
> using gdal_translate gdal_translate — GDAL documentation
> <https://gdal.org/programs/gdal_translate.html>.
> Play with the -srcwin and -projwin / -projwin_srs options and gather some
> trust that is is possible to select and download any part of the large WMTS
> layer. Add “-- debug on” and you will see that GDAL downloads tiles
> separately just like QGIS. Actually, with WMTS it is the only way to
> download data. Maybe you have read the standard already
> https://portal.ogc.org/files/?artifact_id=35326. It is not necessary
> because GDAL knows what to do, but a review every now and then does not
> harm. Especially the TileMatrix and TileMatrixSet things are not
> self-evident, but they provide the answer to the question about how a WMTS
> client knows which row, col, and zoom to download.
> Do not touch the DataWindow. It defines the extent of the whole WMTS layer
> and it is used for example if gdal_translate is run without spatial
> selection (-srcwin or -projwin). Touch in your future code things which are
> equivalent to -srcwin or -projwin of gdal_translate.
> -Jukka Rahkonen-
> *Lähettäjä:* Michał Kowalczuk <michkowalczuk at gmail.com>
> *Lähetetty:* perjantai 31. toukokuuta 2024 15.45
> *Vastaanottaja:* Even Rouault <even.rouault at spatialys.com>
> *Kopio:* Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>;
> gdal-dev at lists.osgeo.org
> *Aihe:* Re: [gdal-dev] GDAL WMTS get tiles no documentation
> Hi, thank you for your replies!
> As I'm still a newbie especially with WMTS. I need to take a step back to
> the basics. Let's forget about multithreading for now.
> - I'm in the stage that I can open a dataset using WMTS service path
> from data provider
> - I can list subdatasets and open the selected layer as a new dataset
> using path from *SUBDATASET_id_NAME*.
> - This dataset reports large height and width values, which is obvious.
> - The first question is how to read any fragment from this dataset
> using *GDALDatasetRasterIO*.
> Is there a similar way to *SpatialFIlter *from vector layers?
> I see in the docs there is a *<DataWindow>* tag for a local service
> descriptions which defines extents of the data. Does it mean that for each
> map extent change I need to create a new local XML file and open a new
> dataset to read demanded bbox?
> Is this the only way for doing it?
> - From other site I noticed that QGIS downloads tiles separately? But
> how it knows which row/col and zoom should be used in GET request? Does
> it use GDAL for WMTS reading at all?
> I will be grateful for any tip and trucks for a newbie ;-)
> Regards,
> Michal
> śr., 29 maj 2024 o 12:41 Even Rouault <even.rouault at spatialys.com>
> napisał(a):
> Hi,
> The WMS cache (which is used underneath by the WMTS driver) writes each
> tiles in a separate file. So if you use multi-threaded, as long as you read
> in parallel different GDALDataset* object on the WMTS filename, and read
> disjoint areas, that should be fine. There might be a slight risk of things
> going bad if you happened to read the same tile from different GDALDataset*
> object at the same time, as it could potentially read a partially written
> cached tile, or concurrently write the tile in the cache and corrupt it.
> The logic is in frmts/wms/gdalwmscache.cpp
> Even
> Le 29/05/2024 à 10:14, Michał Kowalczuk via gdal-dev a écrit :
> Because this is not clear in documentation, especially in WMTS driver
> docs, my question is strictly about this issue to programmers who have
> already explored this topic.
> Regards
> Michal
> W dniu śr., 29.05.2024 o 10:04 Rahkonen Jukka <
> jukka.rahkonen at maanmittauslaitos.fi> napisał(a):
> Hi,
> No, I am not sure because I do not program myself. Reading this document
> https://gdal.org/user/multithreading.html makes me feel that it is
> possible to do some things in parallel, but the programmer must know how to
> do it right.
> -Jukka Rahkonen-
> *Lähettäjä:* Javier Jimenez Shaw <j1 at jimenezshaw.com>
> *Lähetetty:* keskiviikko 29. toukokuuta 2024 10.41
> *Vastaanottaja:* Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
> *Kopio:* Michał Kowalczuk <michkowalczuk at gmail.com>;
> On Wed, 29 May 2024 at 08:59, Rahkonen Jukka via gdal-dev <
> gdal-dev at lists.osgeo.org> wrote:
> Hi,
> When you have a RasterBand from the WMTS data source, it is abstracted
> and you can read the raster data just like from any other data source and
> raster band
> https://gdal.org/tutorials/raster_api_tut.html#reading-raster-data “There
> are a few ways to read raster data, but the most common is via the
> GDALRasterBand::RasterIO() method. This method will automatically take care
> of data type conversion, up/down sampling and windowing.” GDAL knows which
> tiles to read.
> I do not know if the WMTS driver can do parallel tile downloads. If not,
> it is possible to run many RasterIO() at the same time, each reading data
> from a different window like in this rasterio document
> https://rasterio.readthedocs.io/en/latest/topics/concurrency.html.
> Jukka, are you sure you can run several RasterIO in parallel (on the same
> dataset)? in GDAL GeoTIFF you cannot: the cache may be corrupted. In that
> case I open several datasets over the same file. I do not know about WMTS.
> -Jukka Rahkonen-
> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta *Michal
> *Lähetetty:* keskiviikko 29. toukokuuta 2024 9.08
> *Vastaanottaja:* gdal-dev at lists.osgeo.org
> *Aihe:* [gdal-dev] GDAL WMTS get tiles no documentation
> Hi GDAL fellows
> This is my first post on this mailing list, so I'm asking for
> understanding.
> As all we know the purpose of using WMTS over WMS, I'd like to implement
> parallel downloading tiles from service using C API.
> In my opinion GDAL documentation (
> https://gdal.org/drivers/raster/wmts.html) says nothing on this topic.
> I can get capabilities from WMTS, I can open the selected subdataset but
> how to get tiles for given extent? I could not find any information how to
> do it, even in the GDAL tests on github.
> I am kindly asking for tips. It also can be in python. How using pure GDAL
> API fetch tiles to dynamically complete the displayed map. This is my goal.
> Thank you!
> Michal
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240531/ddc25ae9/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240531/ddc25ae9/attachment-0001.png>
