[gdal-dev] GDAL WMTS get tiles no documentation
Michał Kowalczuk
michkowalczuk at gmail.com
Fri May 31 06:57:41 PDT 2024
As you proposed I tested *gdal_translate *utility but for the following
sample command I get an empty image (tested with jpg and png)
gdal_translate "WMTS:
http://maps.wien.gv.at/wmts/1.0.0/WMTSCapabilities.xml,layer=fmzk3dviewer"
[image: image.png]
pt., 31 maj 2024 o 15:31 Michał Kowalczuk <michkowalczuk at gmail.com>
napisał(a):
> Thank you Rukka,
> Since *-srcwin* and *-projwin* are options only for *gdal_translate*
> utility, your suggestion leads me to use *GDALTranslate()* function with
> these parameters.
> This means that I cannot use directly created WMTS dataset to retrieve
> data (using GDALDatasetRasterIO), but create a new (in-memory or
> file-based) for each map extent change.
> And this is the standard way of doing it?
> Do I understand it correctly?
> Michal
> pt., 31 maj 2024 o 15:13 Rahkonen Jukka <
> jukka.rahkonen at maanmittauslaitos.fi> napisał(a):
>> Hi,
>> Before starting to program you can familiar yourself with the topic by
>> using gdal_translate gdal_translate — GDAL documentation
>> <https://gdal.org/programs/gdal_translate.html>.
>> Play with the -srcwin and -projwin / -projwin_srs options and gather some
>> trust that is is possible to select and download any part of the large WMTS
>> layer. Add “-- debug on” and you will see that GDAL downloads tiles
>> separately just like QGIS. Actually, with WMTS it is the only way to
>> download data. Maybe you have read the standard already
>> https://portal.ogc.org/files/?artifact_id=35326. It is not necessary
>> because GDAL knows what to do, but a review every now and then does not
>> harm. Especially the TileMatrix and TileMatrixSet things are not
>> self-evident, but they provide the answer to the question about how a WMTS
>> client knows which row, col, and zoom to download.
>> Do not touch the DataWindow. It defines the extent of the whole WMTS
>> layer and it is used for example if gdal_translate is run without spatial
>> selection (-srcwin or -projwin). Touch in your future code things which are
>> equivalent to -srcwin or -projwin of gdal_translate.
>> -Jukka Rahkonen-
>> *Lähettäjä:* Michał Kowalczuk <michkowalczuk at gmail.com>
>> *Lähetetty:* perjantai 31. toukokuuta 2024 15.45
>> *Vastaanottaja:* Even Rouault <even.rouault at spatialys.com>
>> *Kopio:* Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>;
>> gdal-dev at lists.osgeo.org
>> *Aihe:* Re: [gdal-dev] GDAL WMTS get tiles no documentation
>> Hi, thank you for your replies!
>> As I'm still a newbie especially with WMTS. I need to take a step back to
>> the basics. Let's forget about multithreading for now.
>> - I'm in the stage that I can open a dataset using WMTS service path
>> from data provider
>> - I can list subdatasets and open the selected layer as a new dataset
>> using path from *SUBDATASET_id_NAME*.
>> - This dataset reports large height and width values, which is
>> obvious.
>> - The first question is how to read any fragment from this dataset
>> using *GDALDatasetRasterIO*.
>> Is there a similar way to *SpatialFIlter *from vector layers?
>> I see in the docs there is a *<DataWindow>* tag for a local service
>> descriptions which defines extents of the data. Does it mean that for each
>> map extent change I need to create a new local XML file and open a new
>> dataset to read demanded bbox?
>> Is this the only way for doing it?
>> - From other site I noticed that QGIS downloads tiles separately? But
>> how it knows which row/col and zoom should be used in GET request? Does
>> it use GDAL for WMTS reading at all?
>> I will be grateful for any tip and trucks for a newbie ;-)
>> Regards,
>> Michal
>> śr., 29 maj 2024 o 12:41 Even Rouault <even.rouault at spatialys.com>
>> napisał(a):
>> Hi,
>> The WMS cache (which is used underneath by the WMTS driver) writes each
>> tiles in a separate file. So if you use multi-threaded, as long as you read
>> in parallel different GDALDataset* object on the WMTS filename, and read
>> disjoint areas, that should be fine. There might be a slight risk of things
>> going bad if you happened to read the same tile from different GDALDataset*
>> object at the same time, as it could potentially read a partially written
>> cached tile, or concurrently write the tile in the cache and corrupt it.
>> The logic is in frmts/wms/gdalwmscache.cpp
>> Even
>> Le 29/05/2024 à 10:14, Michał Kowalczuk via gdal-dev a écrit :
>> Because this is not clear in documentation, especially in WMTS driver
>> docs, my question is strictly about this issue to programmers who have
>> already explored this topic.
>> Regards
>> Michal
>> W dniu śr., 29.05.2024 o 10:04 Rahkonen Jukka <
>> Hi,
>> No, I am not sure because I do not program myself. Reading this document
>> https://gdal.org/user/multithreading.html makes me feel that it is
>> possible to do some things in parallel, but the programmer must know how to
>> do it right.
>> -Jukka Rahkonen-
>> *Lähettäjä:* Javier Jimenez Shaw <j1 at jimenezshaw.com>
>> *Lähetetty:* keskiviikko 29. toukokuuta 2024 10.41
>> *Vastaanottaja:* Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
>> *Kopio:* Michał Kowalczuk <michkowalczuk at gmail.com>;
>> On Wed, 29 May 2024 at 08:59, Rahkonen Jukka via gdal-dev <
>> gdal-dev at lists.osgeo.org> wrote:
>> Hi,
>> When you have a RasterBand from the WMTS data source, it is abstracted
>> and you can read the raster data just like from any other data source and
>> raster band
>> https://gdal.org/tutorials/raster_api_tut.html#reading-raster-data
>> “There are a few ways to read raster data, but the most common is via the
>> GDALRasterBand::RasterIO() method. This method will automatically take care
>> of data type conversion, up/down sampling and windowing.” GDAL knows which
>> tiles to read.
>> I do not know if the WMTS driver can do parallel tile downloads. If not,
>> it is possible to run many RasterIO() at the same time, each reading data
>> from a different window like in this rasterio document
>> https://rasterio.readthedocs.io/en/latest/topics/concurrency.html.
>> Jukka, are you sure you can run several RasterIO in parallel (on the same
>> dataset)? in GDAL GeoTIFF you cannot: the cache may be corrupted. In that
>> case I open several datasets over the same file. I do not know about WMTS.
>> -Jukka Rahkonen-
>> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta *Michal
>> *Lähetetty:* keskiviikko 29. toukokuuta 2024 9.08
>> *Vastaanottaja:* gdal-dev at lists.osgeo.org
>> *Aihe:* [gdal-dev] GDAL WMTS get tiles no documentation
>> Hi GDAL fellows
>> This is my first post on this mailing list, so I'm asking for
>> understanding.
>> As all we know the purpose of using WMTS over WMS, I'd like to implement
>> parallel downloading tiles from service using C API.
>> In my opinion GDAL documentation (
>> https://gdal.org/drivers/raster/wmts.html) says nothing on this topic.
>> I can get capabilities from WMTS, I can open the selected subdataset but
>> how to get tiles for given extent? I could not find any information how to
>> do it, even in the GDAL tests on github.
>> I am kindly asking for tips. It also can be in python. How using pure
>> GDAL API fetch tiles to dynamically complete the displayed map. This is my
>> goal.
>> Thank you!
>> Michal
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>> http://www.spatialys.com
>> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240531/b8fd5722/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240531/b8fd5722/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240531/b8fd5722/attachment-0003.png>
