[gdal-dev] ogrtindex, gdaltindex feature request
Scott
public at postholer.com
Fri Nov 1 13:44:19 PDT 2024
The whole, new GTI format got by me until Michael Sumner mentioned it on
slack, which I visit extremely rarely. (Thanks Michael). I've been doing
it in an entirely different way. The feature request is based on that.
The feature request is this:
gdaltindex -co GDALINFO=mymeta catalog.fgb *.tif
or
ogrtindex -co OGRINFO=mymeta catalog.fgb *.shp
This says, create an attribute in the .fgb file called 'mymeta' and
populate it with the equivalent of 'ogrinfo -json' or 'gdalinfo -json'.
Or perhaps:
gdaltindex -co GDALSTATS=mymeta catalog.fgb *.tif
Which is equivalent to 'gdalinfo -json -stats -hist'
I've been doing this as a 2 step process, but it would be really cool to
have it all integrated. I have many raster/vector files of different
formats in a single catalog.gpkg and catalog.fgb. I can easily filter
any by bbox, type or stats.
Why?
If you're grabbing your data from an .fgb file on S3/web server without
an intermediate server or service, using a bbox, it's painless to get
exactly the data you need. Further, you have access to all the
attributes, stats, min, max, stddev for filtering *before* you request
the actual data.
If you don't like cloud native or .fgb and want to access your data via
an API, create your catalog as a .gpkg. Create custom attributes for
filtering and indexes on those attributes, json meta data, etc, and
throw it behind an API.
With a catalog.gpkg you can have all your rasters/vectors in the same
catalog.gpkg and ogr2ogr to an .fgb. Anytime you update/upsert your
.gpkg, recreate the .fgb.
As awesome as STAC is, it's becoming increasingly complex and very slow
with large data sets. Compare that to an -sql query on a single
catalog.gpkg (particularly with spatialite).
If you've made it this far, thanks for listening!
Scott
www.postholer.com
