[gdal-dev] ogrtindex, gdaltindex feature request
Even Rouault
even.rouault at spatialys.com
Fri Nov 1 13:54:42 PDT 2024
Not directly addressing your suggestion, but as an alternative, there's
https://github.com/stac-utils/stac-geoparquet and the GTI driver in
3.10.0 can use them directly:
https://gdal.org/en/latest/drivers/raster/gti.html#stac-geoparquet-support
$ ogrinfo
/vsicurl/https://github.com/stac-utils/stac-geoparquet/raw/main/tests/data/naip.parquet
-al -q
Layer name: naip
OGRFeature(naip):0
type (String) = Feature
stac_version (String) = 1.0.0
stac_extensions (StringList) =
(2:https://stac-extensions.github.io/eo/v1.0.0/schema.json,https://stac-extensions.github.io/projection/v1.0.0/schema.json)
id (String) = ok_m_3409901_nw_14_1_20100425
bbox (RealList) = (4:-100.004084,34.934259,-99.933454,35.00323)
links (String(JSON)) =
[{"href":"https:\/\/planetarycomputer.microsoft.com\/api\/stac\/v1\/collections\/naip","rel":"collection","title":null,"type":"application\/json"},{"href":"https:\/\/planetarycomputer.microsoft.com\/api\/stac\/v1\/collections\/naip","rel":"parent","title":null,"type":"application\/json"},{"href":"https:\/\/planetarycomputer.microsoft.com\/api\/stac\/v1\/","rel":"root","title":null,"type":"application\/json"},{"href":"https:\/\/planetarycomputer.microsoft.com\/api\/stac\/v1\/collections\/naip\/items\/ok_m_3409901_nw_14_1_20100425","rel":"self","title":null,"type":"application\/geo+json"},{"href":"https:\/\/planetarycomputer.microsoft.com\/api\/data\/v1\/item\/map?collection=naip&item=ok_m_3409901_nw_14_1_20100425","rel":"preview","title":"Map
of item","type":"text\/html"}]
assets.image.eo:bands (String(JSON)) =
[{"common_name":"red","description":null,"name":"Red"},{"common_name":"green","description":null,"name":"Green"},{"common_name":"blue","description":null,"name":"Blue"},{"common_name":"nir","description":"near-infrared","name":"NIR"}]
assets.image.href (String) =
https://naipeuwest.blob.core.windows.net/naip/v002/ok/2010/ok_100cm_2010/34099/m_3409901_nw_14_1_20100425.tif
assets.image.roles (StringList) = (1:data)
assets.image.title (String) = RGBIR COG tile
assets.image.type (String) = image/tiff; application=geotiff;
profile=cloud-optimized
assets.rendered_preview.href (String) =
https://planetarycomputer.microsoft.com/api/data/v1/item/preview.png?collection=naip&item=ok_m_3409901_nw_14_1_20100425&assets=image&asset_bidx=image%7C1%2C2%2C3
assets.rendered_preview.rel (String) = preview
assets.rendered_preview.roles (StringList) = (1:overview)
assets.rendered_preview.title (String) = Rendered preview
assets.rendered_preview.type (String) = image/png
assets.thumbnail.href (String) =
https://naipeuwest.blob.core.windows.net/naip/v002/ok/2010/ok_100cm_2010/34099/m_3409901_nw_14_1_20100425.200.jpg
assets.thumbnail.roles (StringList) = (1:thumbnail)
assets.thumbnail.title (String) = Thumbnail
assets.thumbnail.type (String) = image/jpeg
assets.tilejson.href (String) =
https://planetarycomputer.microsoft.com/api/data/v1/item/tilejson.json?collection=naip&item=ok_m_3409901_nw_14_1_20100425&assets=image&asset_bidx=image%7C1%2C2%2C3
assets.tilejson.roles (StringList) = (1:tiles)
assets.tilejson.title (String) = TileJSON with default rendering
assets.tilejson.type (String) = application/json
collection (String) = naip
gsd (Real) = 1
datetime (DateTime) = 2010/04/25 00:00:00+00
naip:year (String) = 2010
proj:bbox (RealList) = (4:408377,3866212,414752,3873800)
proj:epsg (Integer64) = 26914
naip:state (String) = ok
proj:shape (Integer64List) = (2:7588,6375)
proj:transform (RealList) = (9:1,0,408377,0,-1,3873800,0,0,1)
POLYGON ((-99.933454 34.934815,-99.93423 35.00323,-100.004084
35.002673,-100.00325 34.934259,-99.933454 34.934815))
etc.
Le 01/11/2024 à 21:44, Scott via gdal-dev a écrit :
> The whole, new GTI format got by me until Michael Sumner mentioned it
> on slack, which I visit extremely rarely. (Thanks Michael). I've been
> doing it in an entirely different way. The feature request is based on
> that.
> The feature request is this:
> gdaltindex -co GDALINFO=mymeta catalog.fgb *.tif
> or
> ogrtindex -co OGRINFO=mymeta catalog.fgb *.shp
> This says, create an attribute in the .fgb file called 'mymeta' and
> populate it with the equivalent of 'ogrinfo -json' or 'gdalinfo
> -json'. Or perhaps:
> gdaltindex -co GDALSTATS=mymeta catalog.fgb *.tif
> Which is equivalent to 'gdalinfo -json -stats -hist'
> I've been doing this as a 2 step process, but it would be really cool
> to have it all integrated. I have many raster/vector files of
> different formats in a single catalog.gpkg and catalog.fgb. I can
> easily filter any by bbox, type or stats.
> Why?
> If you're grabbing your data from an .fgb file on S3/web server
> without an intermediate server or service, using a bbox, it's painless
> to get exactly the data you need. Further, you have access to all the
> attributes, stats, min, max, stddev for filtering *before* you request
> the actual data.
> If you don't like cloud native or .fgb and want to access your data
> via an API, create your catalog as a .gpkg. Create custom attributes
> for filtering and indexes on those attributes, json meta data, etc,
> and throw it behind an API.
> With a catalog.gpkg you can have all your rasters/vectors in the same
> catalog.gpkg and ogr2ogr to an .fgb. Anytime you update/upsert your
> .gpkg, recreate the .fgb.
> As awesome as STAC is, it's becoming increasingly complex and very
> slow with large data sets. Compare that to an -sql query on a single
> catalog.gpkg (particularly with spatialite).
> If you've made it this far, thanks for listening!
> Scott
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
