[gdal-dev] How to locate where the raster min and max values are?
Even Rouault even.rouault at spatialys.com
Sun Nov 3 04:16:09 PST 2024
See https://github.com/OSGeo/gdal/pull/11200 for an API and sample
script to offer that capability (that can scale to datasets that don't
fit in RAM)
Even
Le 30/10/2024 à 01:31, Rahkonen Jukka via gdal-dev a écrit :
> Hi,
> I would like to know the georeferenced coordinates of the min and max
> values of a DEM file. Even better if I could forward them into a
> vector file. If the minimum or maximum happens to be on a flat area
> like seabed I would be happy with the first pixel at the moment.
> By copy-pasting from How do I open geotiff images with GDAL in Python?
> - Stack Overflow
> <https://stackoverflow.com/questions/41996079/how-do-i-open-geotiff-images-with-gdal-in-python>
> and How to find the indexes of the minimum or maximum value(s) in a
> matrix using python ?
> <https://en.moonbooks.org/Articles/How-to-find-the-indexes-of-the-minimum-or-maximum-values-in-a-matrix-using-python-/>
> I think I managed to get the correct points as numpy indexes
> >>> import numpy as np
> >>> from osgeo import gdal
> >>> ds = gdal.Open('P3412A.tif', gdal.GA_ReadOnly)
> >>> rb = ds.GetRasterBand(1)
> >>> img_array = rb.ReadAsArray()
> >>> vmin = img_array.min()
> >>> vmax = img_array.max()
> >>> vmin
> -0.929
> >>> vmax
> 17.246
> >>> np.where(img_array==vmin)
> (array([1504], dtype=intg64), array([1189], dtype=int64))
> >>> np.where(img_array==vmax)
> (array([1545], dtype=int64), array([2423], dtype=int64))
> But now I have no idea about how to get the georeferenced coordinates.
> The task feels rather simple and I was sure that someone has already
> made an utility or a QGIS plugin, but all I have found yet is for R. I
> was thinking that perhaps some of the gdaldem modes could be misused
> for this purpose, but I believe they cannot. For QGIS I found advice
> to use an obvious but  clumsy method of polygonising the raster and
> finding the extremes from the vector data. And one OpenJUMP developer
> took the challenge and wrote a prototype with Java but it is not
> complete yet.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241103/920d7f4d/attachment.htm>
