[gdal-dev] GPU support for GDAL
Pradeep Mahato pradeep.cabs at gov.in
Thu Nov 7 20:53:29 PST 2024
HI,
This is my project requirement to use GPU for pyramid layer generation. I have through for some solution
1. Using GDAL with GPU support => Not possible
2. Used cuda based library to generate the different layers of pyramid and then stack it and make one ".ovr" as GDAL gives
In second approach i am facing issue in stacking and making it as one ".ovr" file. So Pls help me in this regard.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241108/b671cd63/attachment.htm>
