[gdal-dev] GPU support for GDAL
Javier Jimenez Shaw j1 at jimenezshaw.com
Thu Nov 7 23:33:16 PST 2024
Some time ago I did stack the pyramids writing one level per file, naming
them .ovr, .ovr.ovr, .ovr.ovr.ovr and so on.
I don't know if it would still work
On Fri, 8 Nov 2024, 05:53 Pradeep Mahato via gdal-dev, <
gdal-dev at lists.osgeo.org> wrote:
> HI,
>    This is my project requirement to use GPU for pyramid layer generation.
> I have through for some solution
> 1. Using GDAL with GPU support => Not possible
> 2. Used cuda based library to generate the different layers of pyramid and
> then stack it and make one ".ovr" as GDAL gives
> In second approach i am facing issue in stacking and making it as one
> ".ovr" file. So Pls help me in this regard.
> <https://amritmahotsav.nic.in/>
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241108/4554fbd2/attachment.htm>
