[gdal-dev] GPU support for GDAL
Greg Troxel
gdt at lexort.com
Fri Nov 8 05:08:14 PST 2024
Pradeep Mahato via gdal-dev <gdal-dev at lists.osgeo.org> writes:
> In second approach i am facing issue in stacking and making it as one
> ".ovr" file. So Pls help me in this regard.
If you are going to ask for help, you should have your goals and
software design in writing, and publish them. Before doing that, you
should have it reviewed by others in your organization. Your message
comes across as "I did something (but I'm not actually explaining what I
did), and I didn't get what I wanted (but I'm not telling you what I
wanted), so please do this for me". Overall, it sounds like you need a
consultant.
