[gdal-dev] Issue with the STACIT usage examples
    Rahkonen Jukka
    jukka.rahkonen at maanmittauslaitos.fi
    Thu Nov 21 05:15:20 PST 2024
The examples in https://gdal.org/en/latest/drivers/raster/stacit.html with &bbox in the search parameters may not work as they have used to work.
For example:
gdalinfo "STACIT:\ "https://planetarycomputer.microsoft.com/api/stac/v1/search?collections=naip&bbox=-100,40,-99,41&datetime=2019-01-01T00:00:00Z%2F..\ ":asset=image"
The subdatasets names get printed but at the end of output I see
'bbox' is not recognized as an internal or external command,
operable program or batch file.
'datetime' is not recognized as an internal or external command,
Does it mean that bbox and datetime filters are not applied? A warning "Warning 1: Maximum number of items (1000) allowed to be retrieved has been hit" makes me think so because the search from the API returns 249 items.
I am on Windows.
-Jukka Rahkonen-
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241121/a998068b/attachment.htm>
