[gdal-dev] Issue with the STACIT usage examples
Daniel Evans daniel.fred.evans at gmail.com
Thu Nov 21 05:23:18 PST 2024
Hi Jukka,
Those are errors from your the Windows command prompt. You will need to
escape or enclose some special characters like the ampersands.
On Thu, 21 Nov 2024, 14:15 Rahkonen Jukka via gdal-dev, <
gdal-dev at lists.osgeo.org> wrote:
> Hi,
> The examples in https://gdal.org/en/latest/drivers/raster/stacit.html with
> &bbox in the search parameters may not work as they have used to work.
> For example:
> gdalinfo "STACIT:\ "
> https://planetarycomputer.microsoft.com/api/stac/v1/search?collections=naip&bbox=-100,40,-99,41&datetime=2019-01-01T00:00:00Z%2F..\
> <https://planetarycomputer.microsoft.com/api/stac/v1/search?collections=naip&bbox=-100,40,-99,41&datetime=2019-01-01T00:00:00Z%2F..%5C>
> ":asset=image"
> The subdatasets names get printed but at the end of output I see
> 'bbox' is not recognized as an internal or external command,
> operable program or batch file.
> 'datetime' is not recognized as an internal or external command,
> Does it mean that bbox and datetime filters are not applied? A warning
> “Warning 1: Maximum number of items (1000) allowed to be retrieved has been
> hit” makes me think so because the search from the API returns 249 items.
> I am on Windows.
> -Jukka Rahkonen-
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241121/c51d4b8f/attachment.htm>
