[gdal-dev] Issue with the STACIT usage examples
Even Rouault
even.rouault at spatialys.com
Thu Nov 21 08:35:33 PST 2024
> However, the subdataset names on the list are not accepted as-is
> without small edits.
> Does not work:
> gdalinfo
> STACIT:"https://paituli.csc.fi/geoserver/ogc/stac/v1/search?collections=corine_land_cover_at_geocubes":asset=1000m
That's "expected". Subdataset names are designed to be used verbatim by
GDALOpen(). The STACIT driver isn't aware it has been invoked from a
shell and which quoting rules would apply.
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241121/327edef7/attachment.htm>
