[gdal-dev] Issue with the STACIT usage examples
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Thu Nov 21 08:42:51 PST 2024
Understood, and good reason to start using the new gdalinfo convenience option "-sd" for selecting sub-datasets by their index.
gdalinfo "STACIT:\https://paituli.csc.fi/geoserver/ogc/stac/v1/search?collections=corine_land_cover_at_geocubes\<https://paituli.csc.fi/geoserver/ogc/stac/v1/search?collections=corine_land_cover_at_geocubes%5C>" -sd 2
-Jukka-
Lähettäjä: Even Rouault <even.rouault at spatialys.com>
Lähetetty: torstai 21. marraskuuta 2024 18.36
Vastaanottaja: Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>; Daniel Evans <daniel.fred.evans at gmail.com>
Kopio: 'gdal-dev at lists.osgeo.org' (gdal-dev at lists.osgeo.org) <gdal-dev at lists.osgeo.org>
Aihe: Re: [gdal-dev] Issue with the STACIT usage examples
However, the subdataset names on the list are not accepted as-is without small edits.
Does not work:
gdalinfo STACIT:"https://paituli.csc.fi/geoserver/ogc/stac/v1/search?collections=corine_land_cover_at_geocubes"<https://paituli.csc.fi/geoserver/ogc/stac/v1/search?collections=corine_land_cover_at_geocubes>:asset=1000m
That's "expected". Subdataset names are designed to be used verbatim by GDALOpen(). The STACIT driver isn't aware it has been invoked from a shell and which quoting rules would apply.
http://www.spatialys.com<http://www.spatialys.com/>
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241121/5af158fb/attachment.htm>
