[gdal-dev] Issue with the STACIT usage examples
Rahkonen Jukka
jukka.rahkonen at maanmittauslaitos.fi
Fri Nov 22 01:53:25 PST 2024
In case of STACIT, I can’t discover how to use the vrt:// connection string https://gdal.org/en/latest/drivers/raster/vrt.html#vrt-connection-string with subdataset name (or even without). Can you?
Start with
gdalinfo "STACIT:\https://planetarycomputer.microsoft.com/api/stac/v1/search?collections=naip^&bbox=-100,40,-99,41^&datetime=2019-01-01T00:00:00Z%2F..\
and try to show a vrt:// string for
SUBDATASET_1_NAME=STACIT:https://planetarycomputer.microsoft.com/api/stac/v1/search?collections=naip&bbox=-100,40,-99,41&datetime=2019-01-01T00:00:00Z%2F..:asset=image
-Jukka-
Lähettäjä: Michael Sumner <mdsumner at gmail.com>
Lähetetty: perjantai 22. marraskuuta 2024 11.10
Vastaanottaja: Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
Aihe: Re: [gdal-dev] Issue with the STACIT usage examples
On Fri, 22 Nov 2024, 03:52 Rahkonen Jukka via gdal-dev, <gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>> wrote:
Understood, and good reason to start using the new gdalinfo convenience option "-sd" for selecting sub-datasets by their index.
Do beware that index isn't necessarily reliable (good old netcdf), it can change through an ostensibly consistent dataset while name does remain robust.
vrt:// has sd_name for this purpose, and to avoid driver declaration with full subdataset syntax.
I may have considered sd_name for gdalinfo ?? probably a good idea. And maybe something to put on the 4.0 break list 🙏
Cheers, Mike
gdalinfo "STACIT:\https://paituli.csc.fi/geoserver/ogc/stac/v1/search?collections=corine_land_cover_at_geocubes\<https://paituli.csc.fi/geoserver/ogc/stac/v1/search?collections=corine_land_cover_at_geocubes%5C>" -sd 2
-Jukka-
Lähettäjä: Even Rouault <even.rouault at spatialys.com<mailto:even.rouault at spatialys.com>>
Lähetetty: torstai 21. marraskuuta 2024 18.36
Vastaanottaja: Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>>; Daniel Evans <daniel.fred.evans at gmail.com<mailto:daniel.fred.evans at gmail.com>>
Kopio: 'gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>' (gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>) <gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>>
However, the subdataset names on the list are not accepted as-is without small edits.
Does not work:
gdalinfo STACIT:"https://paituli.csc.fi/geoserver/ogc/stac/v1/search?collections=corine_land_cover_at_geocubes"<https://paituli.csc.fi/geoserver/ogc/stac/v1/search?collections=corine_land_cover_at_geocubes>:asset=1000m
That's "expected". Subdataset names are designed to be used verbatim by GDALOpen(). The STACIT driver isn't aware it has been invoked from a shell and which quoting rules would apply.
http://www.spatialys.com<http://www.spatialys.com/>
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241122/89af5c3d/attachment-0001.htm>
