[gdal-dev] Issue with the STACIT usage examples
Even Rouault
even.rouault at spatialys.com
Fri Nov 22 04:14:35 PST 2024
If you struggle with quoting, the easiest would be to "alias" complex
connections strings as VRT with
gdal_translate "STACIT: .. complex stuff here.." my_stacit.vrt
and the use "vrt://my_stacit.vrt?...."
There should be hardly any performance overhead doing that since the VRT
driver is optimized to detect situations like that where it is used as a
passthrough.
On Linux/Unix you can actually avoid creating an actual vrt file and
just create a symbolic link:
$ ln -sf
"STACIT:\"https://planetarycomputer.microsoft.com/api/stac/v1/search?collections=naip&bbox=-100,40,-99,41&datetime=2019-01-01T00:00:00Z%2F..\":asset=image"
my_stacit
$ gdalinfo vrt://my_stacit
That's a trick I use often to make it easier in QGIS to use such
non-file datasets.
Le 22/11/2024 à 10:53, Rahkonen Jukka via gdal-dev a écrit :
> Hi,
> In case of STACIT, I can’t discover how to use the vrt:// connection
> string
> https://gdal.org/en/latest/drivers/raster/vrt.html#vrt-connection-string
> with subdataset name (or even without). Can you?
> Start with
> gdalinfo
> "STACIT:\https://planetarycomputer.microsoft.com/api/stac/v1/search?collections=naip^&bbox=-100,40,-99,41^&datetime=2019-01-01T00:00:00Z%2F..\
> and try to show a vrt:// string for
> SUBDATASET_1_NAME=STACIT:https://planetarycomputer.microsoft.com/api/stac/v1/search?collections=naip&bbox=-100,40,-99,41&datetime=2019-01-01T00:00:00Z%2F..:asset=image
> -Jukka-
> *Lähettäjä:* Michael Sumner <mdsumner at gmail.com>
> *Lähetetty:* perjantai 22. marraskuuta 2024 11.10
> *Vastaanottaja:* Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
> *Aihe:* Re: [gdal-dev] Issue with the STACIT usage examples
> On Fri, 22 Nov 2024, 03:52 Rahkonen Jukka via gdal-dev,
> <gdal-dev at lists.osgeo.org> wrote:
> Understood, and good reason to start using the new gdalinfo
> convenience option "-sd" for selecting sub-datasets by their index.
> Do beware that index isn't necessarily reliable (good old netcdf), it
> can change through an ostensibly consistent dataset while name does
> remain robust.
> vrt:// has sd_name for this purpose, and to avoid driver declaration
> with full subdataset syntax.
> I may have considered sd_name for gdalinfo ?? probably a good idea.
> And maybe something to put on the 4.0 break list 🙏
> Cheers, Mike
> gdalinfo
> "STACIT:\https://paituli.csc.fi/geoserver/ogc/stac/v1/search?collections=corine_land_cover_at_geocubes\
> <https://paituli.csc.fi/geoserver/ogc/stac/v1/search?collections=corine_land_cover_at_geocubes%5C>"
> -sd 2
> -Jukka-
> *Lähettäjä:* Even Rouault <even.rouault at spatialys.com>
> *Lähetetty:* torstai 21. marraskuuta 2024 18.36
> <jukka.rahkonen at maanmittauslaitos.fi>; Daniel Evans
> <daniel.fred.evans at gmail.com>
> *Kopio:* 'gdal-dev at lists.osgeo.org' (gdal-dev at lists.osgeo.org)
> However, the subdataset names on the list are not accepted
> as-is without small edits.
> Does not work:
> gdalinfo
> STACIT:"https://paituli.csc.fi/geoserver/ogc/stac/v1/search?collections=corine_land_cover_at_geocubes"
> <https://paituli.csc.fi/geoserver/ogc/stac/v1/search?collections=corine_land_cover_at_geocubes>:asset=1000m
> That's "expected". Subdataset names are designed to be used
> verbatim by GDALOpen(). The STACIT driver isn't aware it has been
> invoked from a shell and which quoting rules would apply.
> http://www.spatialys.com
> My software is free, but my time generally not.
> Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241122/1c76e7f2/attachment.htm>
