[gdal-dev] GDAL/OGR missing READ capabilities
Even Rouault even.rouault at spatialys.com
Thu Nov 28 13:04:47 PST 2024
Stephen,
> I have reinstalled the `expat` library but it did not help.
You need to install the *developement* package for expat (likely
"expat-devel" from what I can see), and then rebuild GDAL against it by
first running cmake to cause expat detection to be done again, and then
re-building GDAL
"grep GDAL_USE_EXPAT CMakeCache.txt" should return
"GDAL_USE_EXPAT:BOOL=ON" for things to be properly configured
Even
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
