[gdal-dev] GDAL/OGR missing READ capabilities
Stephen S.
stephen at asitemade4u.com
Thu Nov 28 13:32:40 PST 2024
MERCI Even !! -- je suis français vivant aux U.S.
Thanks Even, will do and will let you know (but I am sure it will work)...
S.
On 11/28/24 16:04, Even Rouault via gdal-dev wrote:
> Stephen,
>> I have reinstalled the `expat` library but it did not help.
> You need to install the *developement* package for expat (likely
> "expat-devel" from what I can see), and then rebuild GDAL against it
> by first running cmake to cause expat detection to be done again, and
> then re-building GDAL
> "grep GDAL_USE_EXPAT CMakeCache.txt" should return
> "GDAL_USE_EXPAT:BOOL=ON" for things to be properly configured
> Even
