[gdal-dev] GDAL/OGR missing READ capabilities
Stephen S. stephen at asitemade4u.com
Thu Nov 28 16:25:30 PST 2024
Hi again Even,
IT WORKED.
Thank you so very much.
S.
On 11/28/24 16:32, Stephen S. via gdal-dev wrote:
> MERCI Even !! -- je suis français vivant aux U.S.
> Thanks Even, will do and will let you know (but I am sure it will
> work)...
> S.
> On 11/28/24 16:04, Even Rouault via gdal-dev wrote:
>> Stephen,
>>> I have reinstalled the `expat` library but it did not help.
>> You need to install the *developement* package for expat (likely
>> "expat-devel" from what I can see), and then rebuild GDAL against it
>> by first running cmake to cause expat detection to be done again, and
>> then re-building GDAL
>> "grep GDAL_USE_EXPAT CMakeCache.txt" should return
>> "GDAL_USE_EXPAT:BOOL=ON" for things to be properly configured
>> Even
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
