[gdal-dev] Motion: adopt RFC 103 - OGR_SCHEMA open option
Rahkonen Jukka
jukka.rahkonen at maanmittauslaitos.fi
Fri Nov 29 09:44:01 PST 2024
+1
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Even Rouault via gdal-dev
Lähetetty: perjantai 29. marraskuuta 2024 19.41
Vastaanottaja: ElPaso <elpaso at itopen.it>; gdal-dev at lists.osgeo.org
Aihe: Re: [gdal-dev] Motion: adopt RFC 103 - OGR_SCHEMA open option
Are PSC members shy or too busy with turkeys ;-) ? In any case,
+1 Even
Le 26/11/2024 à 17:18, ElPaso via gdal-dev a écrit :
Motion:
Adopt RFC 103: OGR_SCHEMA open option[1]
I have updated the RFC [1] with:
- updated JSON schema with field rename support
- removed GDAL_DMD_OGR_SCHEMA_OPEN_OPTION_FLAGS (after talking to Even about using DMD_OPEN_OPTION_LIST instead)
There is also a complete candidate implementation for the GML driver at [2]
Kind regards.
[1] https://github.com/OSGeo/gdal/pull/11071 and formatted: https://gdal--11071.org.readthedocs.build/en/11071/development/rfc/rfc103_schema_open_option.html
[2] https://github.com/OSGeo/gdal/pull/11334
http://www.spatialys.com<http://www.spatialys.com/>
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241129/694649b0/attachment-0001.htm>
