[gdal-dev] Motion: adopt RFC 103 - OGR_SCHEMA open option
Howard Butler
howard at hobu.co
Sat Nov 30 07:41:04 PST 2024
+1 Howard
> On Nov 29, 2024, at 3:31 PM, Javier Jimenez Shaw via gdal-dev <gdal-dev at lists.osgeo.org> wrote:
> +1 Javier
> On Fri, 29 Nov 2024, 18:44 Rahkonen Jukka via gdal-dev, <gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>> wrote:
>> +1
>> -Jukka Rahkonen-
>> Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org <mailto:gdal-dev-bounces at lists.osgeo.org>> Puolesta Even Rouault via gdal-dev
>> Lähetetty: perjantai 29. marraskuuta 2024 19.41
>> Vastaanottaja: ElPaso <elpaso at itopen.it <mailto:elpaso at itopen.it>>; gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>> Aihe: Re: [gdal-dev] Motion: adopt RFC 103 - OGR_SCHEMA open option
>> Are PSC members shy or too busy with turkeys ;-) ? In any case,
>> +1 Even
>> Le 26/11/2024 à 17:18, ElPaso via gdal-dev a écrit :
>> Hi,
>> Motion:
>> Adopt RFC 103: OGR_SCHEMA open option[1]
>> I have updated the RFC [1] with:
>> - updated JSON schema with field rename support
>> - removed GDAL_DMD_OGR_SCHEMA_OPEN_OPTION_FLAGS (after talking to Even about using DMD_OPEN_OPTION_LIST instead)
>> There is also a complete candidate implementation for the GML driver at [2]
>> Kind regards.
>> [1] https://github.com/OSGeo/gdal/pull/11071 and formatted: https://gdal--11071.org.readthedocs.build/en/11071/development/rfc/rfc103_schema_open_option.html
>> [2] https://github.com/OSGeo/gdal/pull/11334
>> http://www.spatialys.com <http://www.spatialys.com/>
>> My software is free, but my time generally not.
>> Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241130/89cda990/attachment.htm>
