[gdal-dev] Build GDAL release/3.9 with HDF5
Parveen Sharma
sharma1981 at outlook.com
Mon Oct 7 00:11:10 PDT 2024
Hi
I am trying to build GDAL from source from "release/3.9 branch".
I am bit confused about the HDF5 flags i need to pass if i want to enable the HDF5 support and also build the HDF5 drivers. I am using following flags BUT i still keep getting errors shown next
<arg value="-DHDF5_FIND_DEBUG=ON" />
<arg value="-DHDF5_DIR=${unpack.dir}/hdf5" />
<arg value="-DHDF5_LIBRARIES=${unpack.dir}/hdf5/lib/hdf5.lib" />
<arg value="-DHDF5_C_LIBRARY=${unpack.dir}/hdf5/lib/hdf5.lib" />
<arg value="-DHDF5_HL_LIBRARY=${unpack.dir}/hdf5/lib/hdf5_hl.lib" />
<arg value="-DHDF5_INCLUDE_DIRS=${unpack.dir}/hdf5_copy/include"/>
<arg value="-DHDF5_C_INCLUDE_DIR=${unpack.dir}/hdf5/include" />
[INFO] [exec] Call Stack (most recent call first):
[INFO] [exec] cmake/helpers/CheckDependentLibraries.cmake:609 (gdal_check_package)
[INFO] [exec] gdal.cmake:266 (include)
[INFO] [exec] -- HDF5_DEFINITIONS: -DH5_BUILT_AS_DYNAMIC_LIB
[INFO] [exec] CMakeLists.txt:240 (include)
[INFO] [exec]
[INFO] [exec]
[INFO] [exec] -- HDF5_INCLUDE_DIRS: C:\Source\gdal_39/dependencies/x64/hdf5_copy/include;C:/Source/gdal_39/dependencies/x64/hdf5/include
[INFO] [exec] -- HDF5_LIBRARIES: C:\Source\gdal_39/dependencies/x64/hdf5/lib/hdf5.lib;C:Source\gdal_39/dependencies/x64/hdf5/lib/hdf5.lib;HDF5_hdf5_LIBRARY-NOTFOUND
[INFO] [exec] -- HDF5_HL_LIBRARIES:
[INFO] [exec] -- HDF5_C_DEFINITIONS:
[INFO] [exec] -- HDF5_C_INCLUDE_DIR: C:/Source/gdal_39/dependencies/x64/hdf5/include
[INFO] [exec] -- HDF5_C_INCLUDE_DIRS: C:/Source/gdal_39/dependencies/x64/hdf5/include
[INFO] [exec] -- HDF5_C_LIBRARY: C:\Source\gdal_39/dependencies/x64/hdf5/lib/hdf5.lib
[INFO] [exec] -- HDF5_C_LIBRARIES: C:\Source\gdal_39/dependencies/x64/hdf5/lib/hdf5.lib;HDF5_hdf5_LIBRARY-NOTFOUND
[INFO] [exec] -- HDF5_C_HL_LIBRARY:
[INFO] [exec] -- HDF5_C_HL_LIBRARIES:
[INFO] [exec] -- Defined targets (if any):
[INFO] [exec] -- Configuring incomplete, errors occurred!
Can anyone assist?
Best regards,
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241007/dac2fa2d/attachment.htm>
