[gdal-dev] writing arrow geometry
Michael Sumner
mdsumner at gmail.com
Mon Oct 7 06:19:42 PDT 2024
When I investigate the schema in one of the test files
ogr/data/arrow/from_paleolimbot_geoarrow/polygon-default.ipc
I see expected list<polygons and list<rings and xy etc. I'm printing this
by using R nanoarrow::read_arrow, or from poLayer->GetArrowStream and I get
the same output:
<nanoarrow_array_stream struct<row_num: int32, geometry:
geoarrow.polygon{list<rings: list<vertices:
geoarrow.point{fixed_size_list(2)<xy: double>}>>}>>
If I write a new .arrow with GDAL
ogr2ogr ~/fromgdal.arrow
the stream schema looks like this:
geoarrow.polygon{list<item: list<item: struct<x: double, y: double>>>}>>
and from nanoarrow I see
nanoarrow::read_nanoarrow("~/fromgdal.arrow")
Error in read_nanoarrow.character("~/fromgdal.arrow") :
array_stream->get_schema(): [29] Expected >= 1330795077 bytes of
remaining data but found 2266 bytes in buffer
Are we in-between moves regarding specifications, or something? I'm having
good results generally and this seems like a problem in the Arrow driver
for write.
Cheers, Mike
Michael Sumner
Research Software Engineer
Australian Antarctic Division
Hobart, Australia
e-mail: mdsumner at gmail.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241008/e838c14c/attachment-0001.htm>
