[gdal-dev] [PROJ] RFC 102: Embedding resource files into libgdal (and PROJ)
Even Rouault even.rouault at spatialys.com
Wed Oct 9 09:12:03 PDT 2024
Proposed implementations are, as far as I can tell, feature complete now
(including docs & CI):
- GDAL: https://github.com/OSGeo/gdal/pull/10972 . I propose that we
target 3.11. We are probably too close to the feature freeze of 3.10 and
would otherwise need to rush things, which feels unnecessary.
- PROJ: https://github.com/OSGeo/PROJ/pull/4265 . Embedding has also
been extended to proj.ini , in addition to proj.db (both available in
non-C23 or C23 modes)
I've also updated the RFC text to reflect the current state of things.
I let more time for people to review before submitting to vote, probably
end of next week (as usual, tell if you need more time)
Even
Le 03/10/2024 à 19:30, Even Rouault via PROJ a écrit :
> Hi,
> I've now a PROJ branch with proj.db embedding working at
> https://github.com/OSGeo/PROJ/pull/4265. And contrary to the current
> wording of the RFC text, I've actually invested in making it work with
> non-C23 compilers too (C23 mechanism used when available), by adapting
> https://gitlab.com/jhamberg/cmake-examples/-/blob/master/cmake/FileEmbed.cmake
> and optimizing it because its performance at generating a .c file from
> a binary was not acceptable on multi-megabyte large files like
> proj.db.  Non-C23 embedding works fine with older gcc, clang, MSVC.
> The proj_db.c generation from proj.db runs in 8 seconds, and building
> it with gcc in 18 seconds (looking at build times in CI, that seems to
> be fast with MSVC too)
> But I won't (probably) support non-C23 embedding for GDAL: that would
> be too much complication w.r.t benefit. Only a "few" GDAL drivers need
> resource files, whereas access to proj.db is a strong requirement.
> Kurt, I had to modify the memOpen() and the memvfs_init() functions of
> the https://www.sqlite.org/src/doc/tip/ext/misc/memvfs.c (I did other
> changes in memvfs_init() to avoid making it the default VFS, and
> registering it per db-connection to avoid a global registration),
> otherwise some complex SQL requests that require creating a temporary
> file wouldn't work, such as the ones of 'bin/projinfo --list-crs' or
> 'bin/cct "this is a bogus CRS meant to trigger a syntax error in
> proj_create"'  (with sqlite 3.46 of fedora:rawhide). Is it something
> you ran into? Cf the changes in memvfs.c in
> https://github.com/rouault/PROJ/commit/e7fcf162f6968c48587836f537b506708112e7d4
> With those changes, ctest pass
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
