[gdal-dev] 2D multiband to 3D MULTIDIM results in duplicated "x" dimension
Michael Sumner
mdsumner at gmail.com
Mon Oct 14 05:10:47 PDT 2024
Possibly this is a fool's errand ...
I want to be able to cast an RGBA file as a Zarr, so first to cast as
multidim I tried the CreateCopy route with NetCDF and I see dimension "x"
repeated, with "y" missing. (I'm using an external file as the existing
test PNG files are square in shape).
from osgeo import gdal
## PNG source is 100x76 * 4 bands
f = "/vsicurl/
https://github.com/cran/png/blob/master/inst/img/Rlogo.png?raw=true"
src_ds = gdal.Open(f)
## set NetCDF metadata to make Bands 0,1,2,3 a Z dimension
size_z = 4
src_ds.SetMetadataItem('NETCDF_DIM_EXTRA', '{Z}')
src_ds.SetMetadataItem('NETCDF_DIM_Z_DEF', f"{{{size_z},4}}")
src_ds.SetMetadataItem('NETCDF_DIM_Z_VALUES', '{1.25,2.50}')
src_ds.SetMetadataItem('Z#axis', 'Z')
# Create netCDF file
gdal.GetDriverByName('netCDF').CreateCopy('out.nc', src_ds)
## investigate shape as a mdim
ds = gdal.OpenEx("out.nc", gdal.OF_MULTIDIM_RASTER)
rootGroup = ds.GetRootGroup()
var = rootGroup.OpenMDArray("Band1")
## we ended up with x,x,Z
[dim.GetSize() for dim in var.GetDimensions()]
#[4, 100, 100]
That looks like a bug?
And, is there a better way to go about this? PNG->ZARR is my target, I'm
fine with programmatic creation of NetCDF, but this could be quite handy as
a two-step conversion from pseudo-3D to actual 3D via the cli with
"gdal_translate -mo ...". (This is not for real work fwiw, just for me
programming at the edges of Zarr, with examples that are clear in visual
terms).
Cheers, Mike
Michael Sumner
Research Software Engineer
Australian Antarctic Division
Hobart, Australia
e-mail: mdsumner at gmail.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241014/10e440ce/attachment.htm>
