[gdal-dev] 2D multiband to 3D MULTIDIM results in duplicated "x" dimension
Even Rouault even.rouault at spatialys.com
Mon Oct 14 06:53:01 PDT 2024
Michael,
fixed per https://github.com/OSGeo/gdal/pull/11005
Otherwise just do "gdal_translate Rlogo.png Rlogo.zarr -of Zarr" . By
default the Zarr driver translates GDAL bands as the Z dimension, unless
you specify the SINGLE_ARRAY=NO creation option, in which case it will
create a Zarr array per band (so a different default as the netCDF driver).
Even
Le 14/10/2024 à 14:10, Michael Sumner via gdal-dev a écrit :
> Possibly this is a fool's errand ...
> I want to be able to cast an RGBA file as a Zarr, so first to cast as
> multidim I tried the CreateCopy route with NetCDF and I see dimension
> "x" repeated, with "y" missing. (I'm using an external file as the
> existing test PNG files are square in shape).
> from osgeo import gdal
> ## PNG source is 100x76 * 4 bands
> f =
> "/vsicurl/https://github.com/cran/png/blob/master/inst/img/Rlogo.png?raw=true"
> src_ds = gdal.Open(f)
> ## set NetCDF metadata to make Bands 0,1,2,3 a Z dimension
> size_z = 4
> src_ds.SetMetadataItem('NETCDF_DIM_EXTRA', '{Z}')
> src_ds.SetMetadataItem('NETCDF_DIM_Z_DEF', f"{{{size_z},4}}")
> src_ds.SetMetadataItem('NETCDF_DIM_Z_VALUES', '{1.25,2.50}')
> src_ds.SetMetadataItem('Z#axis', 'Z')
> # Create netCDF file
> gdal.GetDriverByName('netCDF').CreateCopy('out.nc <http://out.nc>',
> src_ds)
> ## investigate shape as a mdim
> ds = gdal.OpenEx("out.nc <http://out.nc>",  gdal.OF_MULTIDIM_RASTER)
> rootGroup = ds.GetRootGroup()
> var = rootGroup.OpenMDArray("Band1")
> ## we ended up with x,x,Z
> [dim.GetSize() for  dim in  var.GetDimensions()]
> #[4, 100, 100]
> That looks like a bug?
> And, is there a better way to go about this? PNG->ZARR is my target,
> I'm fine with programmatic creation of NetCDF, but this could be quite
> handy as a two-step conversion from pseudo-3D to actual 3D via the cli
> with "gdal_translate -mo ...". (This is not for real work fwiw, just
> for me programming at the edges of Zarr, with examples that are clear
> in visual terms).
> Cheers, Mike
> Michael Sumner
> Research Software Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
Mostly a fool, sometimes acting like a professional (or vice versa)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241014/4e74f591/attachment.htm>
