[gdal-dev] Reprojecting image with lat/lon bands - best practice?
Michael Sumner
mdsumner at gmail.com
Fri Oct 18 14:32:17 PDT 2024
I didn't know you could do that with -to!! That's awesome
On Sat, 19 Oct 2024, 05:01 Even Rouault via gdal-dev, <
gdal-dev at lists.osgeo.org> wrote:
> Conrad,
> Try something like:
> gdal_translate input.tif imagery.vrt -b 3
> gdalwarp imagery.vrt imagery_warped.tif -geoloc -to X_DATASET=input.tif
> -to X_BAND=2 -to Y_DATASET=input.tif -to Y_BAND=1 -to PIXEL_OFFSET=0 -to
> PIXEL_STEP=1 -to LINE_OFFSET=0 -to LINE_STEP=1 -to SRS=EPSG:4326 -a_srs
> EPSG:4326 -overwrite
> Obviously I have most certainly got something wrong in the above, but
> hopefully with a tiny tweaking that should put you on the right track.
> Reference: https://gdal.org/en/latest/development/rfc/rfc4_geolocate.html
> Even
> Le 18/10/2024 à 12:37, Javier Jimenez Shaw via gdal-dev a écrit :
> Is it an actual grid? in the meaning of having constant step size in X and
> Y.
> In that case the geolocation is just the corner and the x and y sizes. You
> can convert to a georeference raster, and warp it.
> If it is not the case, you have something more like a 2D pointcloud, or a
> bunch of poins in a strange vector format.
> On Fri, 18 Oct 2024 at 12:20, Conrad Bielski via gdal-dev <
>> Hello GDAL-experts,
>> normally when I use GDAL for reprojecting imagery, the projection
>> information that I use is the source spatial reference (SRS) associated
>> with the imagery. However, now I have imagery which is lat/lon geographic
>> and I have two separate bands which also carry the pixel geographic
>> information. So the following raster inputs all the same size:
>> 1. Band 1 = latitude
>> 2. Band 2 = longitude
>> 3. Band 3 = imagery
>> The question I have is how best to integrate this information into a
>> reprojection workflow?
>> I presume that gdalwarp is the best option here, but how can I take
>> advantage of the individual pixel location information (rather than just
>> the extents for example)? I know that I can mosaic into an existing file
>> that I have already created in the target projection. Is this the best way
>> to apply gdalwarp in this context?
>> I'm just wondering what is the best way to integrate the lat/lon pixel
>> information into my warping using gdalwarp.
>> Thanks in advance for your help,
>> Conrad
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
> Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241019/fa50871f/attachment.htm>
