[gdal-dev] Reprojecting image with lat/lon bands - best practice?
Even Rouault
even.rouault at spatialys.com
Fri Oct 18 20:44:16 PDT 2024
Le 18/10/2024 à 23:32, Michael Sumner a écrit :
> I didn't know you could do that with -to!! That's awesome
Hum, sorry for giving a wrong track, it seems the newly LLM module
implemented in my brain has hallucinated...
So you have rather to create a geoloc.vrt file with
gdal_translate input.tif geoloc.vrt -b 2 -b 1
and then;
gdal_translate input.tif imagery.vrt -b 3
gdalwarp imagery.vrt imagery_warped.tif -geoloc -to
GEOLOC_ARRAY=geoloc.vrt -a_srs EPSG:4326 -overwrite
> On Sat, 19 Oct 2024, 05:01 Even Rouault via gdal-dev,
> <gdal-dev at lists.osgeo.org> wrote:
> Conrad,
> Try something like:
> X_DATASET=input.tif -to X_BAND=2 -to Y_DATASET=input.tif -to
> Y_BAND=1 -to PIXEL_OFFSET=0 -to PIXEL_STEP=1 -to LINE_OFFSET=0 -to
> LINE_STEP=1 -to SRS=EPSG:4326 -a_srs EPSG:4326 -overwrite
> Obviously I have most certainly got something wrong in the above,
> but hopefully with a tiny tweaking that should put you on the
> right track.
> Reference:
> https://gdal.org/en/latest/development/rfc/rfc4_geolocate.html
> Even
> Le 18/10/2024 à 12:37, Javier Jimenez Shaw via gdal-dev a écrit :
>> Is it an actual grid? in the meaning of having constant step size
>> in X and Y.
>> In that case the geolocation is just the corner and the x and y
>> sizes. You can convert to a georeference raster, and warp it.
>> If it is not the case, you have something more like a 2D
>> pointcloud, or a bunch of poins in a strange vector format.
>> On Fri, 18 Oct 2024 at 12:20, Conrad Bielski via gdal-dev
>> Hello GDAL-experts,
>> normally when I use GDAL for reprojecting imagery, the
>> projection information that I use is the source spatial
>> reference (SRS) associated with the imagery. However, now I
>> have imagery which is lat/lon geographic and I have two
>> separate bands which also carry the pixel geographic
>> information. So the following raster inputs all the same size:
>> 1. Band 1 = latitude
>> 2. Band 2 = longitude
>> 3. Band 3 = imagery
>> The question I have is how best to integrate this information
>> into a reprojection workflow?
>> I presume that gdalwarp is the best option here, but how can
>> I take advantage of the individual pixel location information
>> (rather than just the extents for example)? I know that I can
>> mosaic into an existing file that I have already created in
>> the target projection. Is this the best way to apply gdalwarp
>> in this context?
>> I'm just wondering what is the best way to integrate the
>> lat/lon pixel information into my warping using gdalwarp.
>> Thanks in advance for your help,
>> Conrad
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
> Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241019/8e5303aa/attachment-0001.htm>
