[gdal-dev] Reprojecting image with lat/lon bands - best practice?
    Michael Sumner
    mdsumner at gmail.com
    Fri Oct 18 21:47:32 PDT 2024
Nice one, thanks! (I had a fomenting PR to implement on the fly geolocation
array config, so I'll use your hallucination for the design phase).
On Sat, 19 Oct 2024, 14:44 Even Rouault, <even.rouault at spatialys.com> wrote:
> Le 18/10/2024 à 23:32, Michael Sumner a écrit :
> I didn't know you could do that with -to!! That's awesome
> Hum, sorry for giving a wrong track, it seems the newly LLM module
> implemented in my brain has hallucinated...
> So you have rather to create a geoloc.vrt file with
> gdal_translate input.tif geoloc.vrt -b 2 -b 1
> and then;
> gdal_translate input.tif imagery.vrt -b 3
> gdalwarp imagery.vrt imagery_warped.tif -geoloc -to
> GEOLOC_ARRAY=geoloc.vrt -a_srs EPSG:4326  -overwrite
> On Sat, 19 Oct 2024, 05:01 Even Rouault via gdal-dev, <
> gdal-dev at lists.osgeo.org> wrote:
>> Conrad,
>> Try something like:
>> gdalwarp imagery.vrt imagery_warped.tif -geoloc -to X_DATASET=input.tif
>> -to X_BAND=2 -to Y_DATASET=input.tif -to Y_BAND=1 -to PIXEL_OFFSET=0 -to
>> PIXEL_STEP=1 -to LINE_OFFSET=0 -to LINE_STEP=1 -to SRS=EPSG:4326 -a_srs
>> Obviously I have most certainly got something wrong in the above, but
>> hopefully with a tiny tweaking that should put you on the right track.
>> Reference: https://gdal.org/en/latest/development/rfc/rfc4_geolocate.html
>> Even
>> Le 18/10/2024 à 12:37, Javier Jimenez Shaw via gdal-dev a écrit :
>> Is it an actual grid? in the meaning of having constant step size in X
>> and Y.
>> In that case the geolocation is just the corner and the x and y sizes.
>> You can convert to a georeference raster, and warp it.
>> If it is not the case, you have something more like a 2D pointcloud, or a
>> bunch of poins in a strange vector format.
>> On Fri, 18 Oct 2024 at 12:20, Conrad Bielski via gdal-dev <
>>> Hello GDAL-experts,
>>> normally when I use GDAL for reprojecting imagery, the projection
>>> information that I use is the source spatial reference (SRS) associated
>>> with the imagery. However, now I have imagery which is lat/lon geographic
>>> and I have two separate bands which also carry the pixel geographic
>>> information. So the following raster inputs all the same size:
>>> 1. Band 1 = latitude
>>> 2. Band 2 = longitude
>>> 3. Band 3 = imagery
>>> The question I have is how best to integrate this information into a
>>> reprojection workflow?
>>> I presume that gdalwarp is the best option here, but how can I take
>>> advantage of the individual pixel location information (rather than just
>>> the extents for example)? I know that I can mosaic into an existing file
>>> that I have already created in the target projection. Is this the best way
>>> to apply gdalwarp in this context?
>>> I'm just wondering what is the best way to integrate the lat/lon pixel
>>> information into my warping using gdalwarp.
>>> Thanks in advance for your help,
>>> Conrad
>>> gdal-dev mailing list
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
>> -- http://www.spatialys.com
>> My software is free, but my time generally not.
>> Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241019/0bb51886/attachment.htm>
