[gdal-dev] GDAL 3.10.0 beta1 available for testing
Even Rouault
even.rouault at spatialys.com
Sun Oct 20 06:35:06 PDT 2024
Holger,
thanks for the report. The issues you hit are not related to packaging.
Will be fixed per https://github.com/OSGeo/gdal/pull/11054
Even
Le 20/10/2024 à 15:04, Holger Jaekel via gdal-dev a écrit :
> Am 15.10.24 um 13:54 schrieb Even Rouault via gdal-dev:
>> I've prepared a beta1 of GDAL 3.10.0 to get feedback from early testers,
> Even,
> GDAL 3.10.0 beta1 builds well on Alpine Linux Edge.
> To test the new driver for XODR, I created the libopendrive package and
> built GDAL with OpenDRIVE support. Now I get:
> $ ogrinfo
> https://raw.githubusercontent.com/pageldev/libOpenDRIVE/refs/heads/master/test.xodr
> File was not found
> ERROR 1: PROJ: proj_create: unrecognized format / unknown name
> INFO: Open of
> `https://raw.githubusercontent.com/pageldev/libOpenDRIVE/refs/heads/master/test.xodr'
> using driver `XODR' successful.
> 1: ReferenceLine (3D Line String)
> 2: LaneBorder (3D Line String)
> 3: RoadMark (3D TIN)
> 4: RoadObject (3D TIN)
> 5: Lane (3D TIN)
> 6: RoadSignal (3D TIN)
> Do you know where the "File was not found" message and the error in
> proj_create come from?
> Holger
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
