[gdal-dev] GDAL 3.10.0 beta1 available for testing
Holger Jaekel
holger.jaekel at gmx.de
Sun Oct 20 06:04:52 PDT 2024
Am 15.10.24 um 13:54 schrieb Even Rouault via gdal-dev:
> I've prepared a beta1 of GDAL 3.10.0 to get feedback from early testers,
Even,
GDAL 3.10.0 beta1 builds well on Alpine Linux Edge.
To test the new driver for XODR, I created the libopendrive package and
built GDAL with OpenDRIVE support. Now I get:
$ ogrinfo
https://raw.githubusercontent.com/pageldev/libOpenDRIVE/refs/heads/master/test.xodr
File was not found
ERROR 1: PROJ: proj_create: unrecognized format / unknown name
INFO: Open of
`https://raw.githubusercontent.com/pageldev/libOpenDRIVE/refs/heads/master/test.xodr'
using driver `XODR' successful.
1: ReferenceLine (3D Line String)
2: LaneBorder (3D Line String)
3: RoadMark (3D TIN)
4: RoadObject (3D TIN)
5: Lane (3D TIN)
6: RoadSignal (3D TIN)
Do you know where the "File was not found" message and the error in
proj_create come from?
Holger
