[gdal-dev] Interest for a driver to read Phase One IIQ images?
Even Rouault even.rouault at spatialys.com
Sat Oct 26 04:09:49 PDT 2024
Esri has developed a GDAL driver to be able to read for the Phase One
IIQ format (that they use in ArcGIS). Phase One
(https://www.phaseone.com/) makes aerial, UAV, and space cameras.
The PhaseOne file format (IIQ) is TIFF, storing a full-resolution raw
(compressed Bayer) image in a custom tag. The GDAL driver needs to be
built against a proprietary SDK (ImageSDK) for decoding such images:
https://developer.phaseone.com/sdk/3.1/docs/appendices/download.html .
The source code of the IIQ GDAL driver itself isn't that large (700 lines).
Is there an interest in having that driver in the OSGeo/GDAL repository?
Due to the proprietary nature of the PhaseOne SDK, the IIQ driver
wouldn't be available in the common packaging systems people usually get
GDAL from, and would have to be built as a plugin from source (or doing
a full build with it enabled). Otherwise Esri expressed the intent of
publicly releasing the source code of the driver in a separate repository?
Even
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
