[gdal-dev] Interest for a driver to read Phase One IIQ images?
Even Rouault
even.rouault at spatialys.com
Wed Oct 30 06:18:03 PDT 2024
just got one private email from a user up to now: "multiple NASA
airborne observatories use Phase One cameras, and we are considering
their rad-hard detectors for future satellite missions. Would be great
to have optimized driver for these large images." (note of myself: as
far as I can see from the driver code: it/the SDK decompresses the full
image at once, so "large" will be determined by how much RAM you have)
PSC: thoughts ?
Even
Le 26/10/2024 à 13:09, Even Rouault via gdal-dev a écrit :
> Hi,
> Esri has developed a GDAL driver to be able to read for the Phase One
> IIQ format (that they use in ArcGIS). Phase One
> (https://www.phaseone.com/) makes aerial, UAV, and space cameras.
> The PhaseOne file format (IIQ) is TIFF, storing a full-resolution raw
> (compressed Bayer) image in a custom tag. The GDAL driver needs to be
> built against a proprietary SDK (ImageSDK) for decoding such images:
> https://developer.phaseone.com/sdk/3.1/docs/appendices/download.html .
> The source code of the IIQ GDAL driver itself isn't that large (700
> lines).
> Is there an interest in having that driver in the OSGeo/GDAL
> repository? Due to the proprietary nature of the PhaseOne SDK, the IIQ
> driver wouldn't be available in the common packaging systems people
> usually get GDAL from, and would have to be built as a plugin from
> source (or doing a full build with it enabled). Otherwise Esri
> expressed the intent of publicly releasing the source code of the
> driver in a separate repository?
> Even
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
