[gdal-dev] Abou R sf library and GDAL
Michael Sumner mdsumner at gmail.com
Mon Oct 28 12:45:18 PDT 2024
It's not RStudio or sf specific though, I think it's worth asking here
because there are many many R packages using GDAL and they essentially
share the same simple installation, after the GDAL version choice has been
made. What really matters is your operating system and the method you have
available for installing GDAL itself. On windows and macos you get the
versions built by CRAN itself, on Linux you get the version supported by
your distro.
sf repo isn't a general place to get support so I wouldn't encourage asking
there, I'm happy to help point to options if you share details of your
compute setup
Cheers, Mike
On Tue, 29 Oct 2024, 03:16 Abel Pau via gdal-dev, <gdal-dev at lists.osgeo.org>
wrote:
> Ok Even. Thanks for the answer.
> I’ll ask there!
> *De:* Even Rouault <even.rouault at spatialys.com>
> *Enviado el:* dilluns, 28 d’octubre de 2024 17:12
> *Para:* Abel Pau <a.pau at creaf.cat>; gdal-dev at lists.osgeo.org
> *Asunto:* Re: [gdal-dev] Abou R sf library and GDAL
> Abel,
> That would probably be more a topic for
> https://github.com/r-spatial/sf/discussions or other "sf" related channels
> Even
> Le 28/10/2024 à 16:53, Abel Pau via gdal-dev a écrit :
> Good afternoon,
> Lately, we have been trying to use RStudio to work with files supported by
> the GDAL libraries. The latest version of the "sf" library is from 2022-23
> (version 18), and we’re unsure if it updates frequently or if it needs to
> be manually compiled. We would be interested in having one of the more
> recent versions from the last few months (such as 3.9 or 3.10, for example).
> Could you please explain a bit, if you know, the method for updating GDAL
> within RStudio (or other R softwares)?
> Thank you very much.
> *Abel Pau Garcia*
> [image: https://www.creaf.cat/sites/default/files/logo-creaf-small.jpg]
> <https://www.creaf.cat/>
> *GIS developer*
> *a.pau at creaf.uab.cat* <a.pau at creaf.uab.cat>
> [image: https://www.creaf.cat/sites/default/files/cap_0.png]
> *Let's chat on Teams!*
> <https://teams.microsoft.com/l/chat/0/0?users=a.pau@creaf.uab.cat>
> *Tel. +34 934814277 *
> [image: https://www.creaf.cat/sites/default/files/x_30.png]
> <https://twitter.com/CREAF_ecologia>[image:
> https://www.creaf.cat/sites/default/files/linkedin_30.png]
> <https://www.linkedin.com/company/creaf/>[image:
> https://www.creaf.cat/sites/default/files/youtube_30.png]
> <https://www.youtube.com/c/creafecologia>[image:
> https://www.creaf.cat/sites/default/files/instagram_30.png]
> <https://www.instagram.com/CREAF_ecologia/>
> *www.creaf.cat* <http://www.creaf.cat>*| **http://blog.creaf.cat*
> <http://blog.creaf.cat>
> CREAF. Campus UAB. Edifici C. 08193 Bellaterra (Barcelona)
> <https://www.openstreetmap.org/way/123379060>
> *Política de privacitat* <https://www.creaf.cat/ca/politica-de-privacitat>
> [image: https://www.creaf.cat/sites/default/files/corner_right_0.png]
> Abans d'imprimir aquest missatge electrònic penseu en el medi ambient.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
> Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241029/1507e591/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241029/1507e591/attachment-0001.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241029/1507e591/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241029/1507e591/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241029/1507e591/attachment-0009.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241029/1507e591/attachment-0010.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241029/1507e591/attachment-0011.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241029/1507e591/attachment-0012.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241029/1507e591/attachment-0013.png>
