[gdal-dev] Abou R sf library and GDAL
Gerald Nelson
nelson.gerald.c at gmail.com
Mon Oct 28 12:50:07 PDT 2024
May I suggest using the R package terra.
Get Outlook for iOS<https://aka.ms/o0ukef>
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Michael Sumner via gdal-dev <gdal-dev at lists.osgeo.org>
Sent: Monday, October 28, 2024 1:45:18 PM
To: Abel Pau <a.pau at creaf.cat>
Cc: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] Abou R sf library and GDAL
It's not RStudio or sf specific though, I think it's worth asking here because there are many many R packages using GDAL and they essentially share the same simple installation, after the GDAL version choice has been made. What really matters is your operating system and the method you have available for installing GDAL itself. On windows and macos you get the versions built by CRAN itself, on Linux you get the version supported by your distro.
sf repo isn't a general place to get support so I wouldn't encourage asking there, I'm happy to help point to options if you share details of your compute setup
Cheers, Mike
On Tue, 29 Oct 2024, 03:16 Abel Pau via gdal-dev, <gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>> wrote:
Ok Even. Thanks for the answer.
I’ll ask there!
De: Even Rouault <even.rouault at spatialys.com<mailto:even.rouault at spatialys.com>>
Enviado el: dilluns, 28 d’octubre de 2024 17:12
Para: Abel Pau <a.pau at creaf.cat<mailto:a.pau at creaf.cat>>; gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Asunto: Re: [gdal-dev] Abou R sf library and GDAL
Abel,
That would probably be more a topic for https://github.com/r-spatial/sf/discussions or other "sf" related channels
Even
Le 28/10/2024 à 16:53, Abel Pau via gdal-dev a écrit :
Good afternoon,
Lately, we have been trying to use RStudio to work with files supported by the GDAL libraries. The latest version of the "sf" library is from 2022-23 (version 18), and we’re unsure if it updates frequently or if it needs to be manually compiled. We would be interested in having one of the more recent versions from the last few months (such as 3.9 or 3.10, for example).
Could you please explain a bit, if you know, the method for updating GDAL within RStudio (or other R softwares)?
Thank you very much.
Abel Pau Garcia
[https://www.creaf.cat/sites/default/files/logo-creaf-small.jpg]<https://www.creaf.cat/>
GIS developer
a.pau at creaf.uab.cat <mailto:a.pau at creaf.uab.cat>
[https://www.creaf.cat/sites/default/files/cap_0.png]
Let's chat on Teams! <https://teams.microsoft.com/l/chat/0/0?users=a.pau@creaf.uab.cat>
Tel. +34 934814277
[https://www.creaf.cat/sites/default/files/x_30.png]<https://twitter.com/CREAF_ecologia>[https://www.creaf.cat/sites/default/files/linkedin_30.png]<https://www.linkedin.com/company/creaf/>[https://www.creaf.cat/sites/default/files/youtube_30.png]<https://www.youtube.com/c/creafecologia>[https://www.creaf.cat/sites/default/files/instagram_30.png]<https://www.instagram.com/CREAF_ecologia/>
www.creaf.cat <http://www.creaf.cat> | http://blog.creaf.cat
CREAF. Campus UAB. Edifici C. 08193 Bellaterra (Barcelona) <https://www.openstreetmap.org/way/123379060>
Política de privacitat <https://www.creaf.cat/ca/politica-de-privacitat>
[https://www.creaf.cat/sites/default/files/corner_right_0.png]
Abans d'imprimir aquest missatge electrònic penseu en el medi ambient.
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241028/ad05ab40/attachment.htm>
