[gdal-dev] GDAL 3.10.0 release candidate is available
Even Rouault even.rouault at spatialys.com
Tue Oct 29 06:14:25 PDT 2024
I have prepared a GDAL/OGR 3.10.0 release candidate.
I'll call for a vote promoting it later this week if no serious problems are
reported before.
NEWS at:
   https://github.com/OSGeo/gdal/blob/v3.10.0RC1/NEWS.md
Pick up an archive among the following ones (by ascending size):
   https://download.osgeo.org/gdal/3.10.0/gdal-3.10.0rc1.tar.xz
   https://download.osgeo.org/gdal/3.10.0/gdal-3.10.0rc1.tar.gz
   https://download.osgeo.org/gdal/3.10.0/gdal3100rc1.zip
A snapshot of the gdalautotest suite is also available :
https://download.osgeo.org/gdal/3.10.0/gdalautotest-3.10.0rc1.tar.gz
https://download.osgeo.org/gdal/3.10.0/gdalautotest-3.10.0rc1.zip
A snapshot of the documentation is at:
   https://download.osgeo.org/gdal/3.10.0/gdal3100doc.zip
There are no major changes, impacting packaging or integration, since
beta1, but
functional bugfixes and enhancements:
* Warper: fix shifted/aliased result with Lanczos resampling when XSCALE
< 1 or
   YSCALE < 1 (#11042)
* Warper: optimize speed of Lanczos resampling in Byte case without any
   masking/alpha
* gdalbuildvrt: add a -co switch (#11062)
* DIMAP driver: use the new color interpretations for the NIR, RedEdge
   and DeepBlue/Coastal bands
* tif_jxl: writer: propagate DISTANCE/QUALITY setting to extra channel
* GTiff: fix memory leak when trying to open COG in update mode
* JP2Lura driver: fix Identify() method
* JP2Lura driver: planned for removal in GDAL 3.11
* JPEGXL driver: writer: propagate DISTANCE/QUALITY setting to extra
channel (#11095)
* JPEGXL driver: writer: allow a minimum DISTANCE of 0.01, max of 25 and
revise QUALITY to
   DISTANCE formula (#11095)
* Zarr V2 creation: fix bug when creating dataset with partial blocks
and need
    to re-read them in the writing process when compression is involved
(#11016)
* Zarr: Create(): remove created files / directories if an error occurs
(#11023)
* Arrow reading: generic code path (as used by GeoJSON): fix mis-handling of
   timezones
* ogr_core.h: suppress warning when building with -Wpedantic for C < 23
(#2322)
* Add OSRGetAuthorityListFromDatabase() to get the list of CRS
authorities used
   in the PROJ database.
* ogr2ogr: fix -explodecollections on empty geometries (#11
* Add (minimum) support for libarrow 18.0.0
* FileGDB/OpenFileGDB drivers: upldate list of reserved keywords (#11094)
* GML: add a GML_DOWNLOAD_SCHEMA config option matching the
DOWNLOAD_SCHEMA open
   option (and deprecate undocumented GML_DOWNLOAD_WFS_SCHEMA)
* GPKG driver: prevent from creating field with same name, or with the
name of
   the geometry field
* GPKG driver: CreateField(): check we are not reaching the max number
of fields
* SQLite/GPKG: turn on SQLite 'PRAGMA secure_delete=1' by default
* OCI driver: use TIMESTAMP(3) and tweak NLS_TIME[STAMP][_TZ]_FORMAT to
accept
   milliseconds (#11057)
* PDF driver: reader: fixes to handle recursive resources, /OC property
attached
   to a XObject and an empty UTF-16 layer name (#11034)
* SWIG bindings: fix memleak in gdal.GetConfigOptions()
* Python bindings: __init__.py: remove calls to warnings.simplefilter()
(#11140)
* Python bindings: fix compatibility issue with SWIG 4.3.0 and
PYTHONWARNINGS=error
Best regards,
Even
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
