[gdal-dev] GDAL 3.10.0 release candidate is available
Sean Gillies
sean.gillies at gmail.com
Tue Oct 29 09:23:29 PDT 2024
Hi Even,
Rasterio still has a problem with the lock-down of MEM:: datasets. I missed
a few spots where GDAL warp utilities open the datasets behind the scenes.
I think I should be able to make a new release by the end of the week.
On Tue, Oct 29, 2024 at 7:14 AM Even Rouault via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hi,
> I have prepared a GDAL/OGR 3.10.0 release candidate.
> I'll call for a vote promoting it later this week if no serious problems
> are
> reported before.
> NEWS at:
> https://github.com/OSGeo/gdal/blob/v3.10.0RC1/NEWS.md
> Pick up an archive among the following ones (by ascending size):
> https://download.osgeo.org/gdal/3.10.0/gdal-3.10.0rc1.tar.xz
> https://download.osgeo.org/gdal/3.10.0/gdal-3.10.0rc1.tar.gz
> https://download.osgeo.org/gdal/3.10.0/gdal3100rc1.zip
> A snapshot of the gdalautotest suite is also available :
> https://download.osgeo.org/gdal/3.10.0/gdalautotest-3.10.0rc1.tar.gz
> https://download.osgeo.org/gdal/3.10.0/gdalautotest-3.10.0rc1.zip
> A snapshot of the documentation is at:
> https://download.osgeo.org/gdal/3.10.0/gdal3100doc.zip
> There are no major changes, impacting packaging or integration, since
> beta1, but
> functional bugfixes and enhancements:
> * Warper: fix shifted/aliased result with Lanczos resampling when XSCALE
> < 1 or
> YSCALE < 1 (#11042)
> * Warper: optimize speed of Lanczos resampling in Byte case without any
> masking/alpha
> * gdalbuildvrt: add a -co switch (#11062)
> * DIMAP driver: use the new color interpretations for the NIR, RedEdge
> and DeepBlue/Coastal bands
> * tif_jxl: writer: propagate DISTANCE/QUALITY setting to extra channel
> * GTiff: fix memory leak when trying to open COG in update mode
> * JP2Lura driver: fix Identify() method
> * JP2Lura driver: planned for removal in GDAL 3.11
> * JPEGXL driver: writer: propagate DISTANCE/QUALITY setting to extra
> channel (#11095)
> * JPEGXL driver: writer: allow a minimum DISTANCE of 0.01, max of 25 and
> revise QUALITY to
> DISTANCE formula (#11095)
> * Zarr V2 creation: fix bug when creating dataset with partial blocks
> and need
> to re-read them in the writing process when compression is involved
> (#11016)
> * Zarr: Create(): remove created files / directories if an error occurs
> (#11023)
> * Arrow reading: generic code path (as used by GeoJSON): fix mis-handling
> of
> timezones
> * ogr_core.h: suppress warning when building with -Wpedantic for C < 23
> (#2322)
> * Add OSRGetAuthorityListFromDatabase() to get the list of CRS
> authorities used
> in the PROJ database.
> * ogr2ogr: fix -explodecollections on empty geometries (#11
> * Add (minimum) support for libarrow 18.0.0
> * FileGDB/OpenFileGDB drivers: upldate list of reserved keywords (#11094)
> * GML: add a GML_DOWNLOAD_SCHEMA config option matching the
> DOWNLOAD_SCHEMA open
> option (and deprecate undocumented GML_DOWNLOAD_WFS_SCHEMA)
> * GPKG driver: prevent from creating field with same name, or with the
> name of
> the geometry field
> * GPKG driver: CreateField(): check we are not reaching the max number
> of fields
> * SQLite/GPKG: turn on SQLite 'PRAGMA secure_delete=1' by default
> * OCI driver: use TIMESTAMP(3) and tweak NLS_TIME[STAMP][_TZ]_FORMAT to
> accept
> milliseconds (#11057)
> * PDF driver: reader: fixes to handle recursive resources, /OC property
> attached
> to a XObject and an empty UTF-16 layer name (#11034)
> * SWIG bindings: fix memleak in gdal.GetConfigOptions()
> * Python bindings: __init__.py: remove calls to warnings.simplefilter()
> (#11140)
> * Python bindings: fix compatibility issue with SWIG 4.3.0 and
> PYTHONWARNINGS=error
> Best regards,
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> Butcher of all kinds of standards, open or closed formats. At the end,
> this is just about bytes.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241029/7c576fb9/attachment.htm>
