[gdal-dev] How to locate where the raster min and max values are?
Even Rouault even.rouault at spatialys.com
Tue Oct 29 17:52:26 PDT 2024
Slightly less tricky using gdal.ApplyGeoTransform() (note the explicit
cast of line[0]/col[0]) as a int, to avoid a numpy type to be used,
which confuses gdal.ApplyGeoTransform) :
import numpy as np
from osgeo import gdal
ds = gdal.Open('byte.tif', gdal.GA_ReadOnly)
rb = ds.GetRasterBand(1)
img_array = rb.ReadAsArray()
vmin = img_array.min()
(line, col) = np.where(img_array==vmin)
line = int(line[0])
col = int(col[0])
print(f"col={col}, line={line}")
gt = ds.GetGeoTransform()
X, Y = gdal.ApplyGeoTransform(gt, col, line)
print(f"X={X}, Y={Y}")
Le 30/10/2024 à 01:41, Even Rouault via gdal-dev a écrit :
> if you are just interested in any point where the minimum is reached:
> import numpy as np
> ds = gdal.Open('P3412A.tif', gdal.GA_ReadOnly)
> line = line[0]
> col = col[0]
> X = gt[0] + gt[1] * col + gt[2] * line
> Y = gt[3] + gt[4] * col + gt[5] * line
> Le 30/10/2024 à 01:31, Rahkonen Jukka via gdal-dev a écrit :
>> Hi,
>> I would like to know the georeferenced coordinates of the min and max
>> values of a DEM file. Even better if I could forward them into a
>> vector file. If the minimum or maximum happens to be on a flat area
>> like seabed I would be happy with the first pixel at the moment.
>> By copy-pasting from How do I open geotiff images with GDAL in
>> Python? - Stack Overflow
>> <https://stackoverflow.com/questions/41996079/how-do-i-open-geotiff-images-with-gdal-in-python>
>> and How to find the indexes of the minimum or maximum value(s) in a
>> matrix using python ?
>> <https://en.moonbooks.org/Articles/How-to-find-the-indexes-of-the-minimum-or-maximum-values-in-a-matrix-using-python-/>
>> I think I managed to get the correct points as numpy indexes
>> >>> import numpy as np
>> >>> vmax = img_array.max()
>> >>> vmin
>> -0.929
>> >>> vmax
>> 17.246
>> (array([1504], dtype=intg64), array([1189], dtype=int64))
>> >>> np.where(img_array==vmax)
>> (array([1545], dtype=int64), array([2423], dtype=int64))
>> But now I have no idea about how to get the georeferenced coordinates.
>> The task feels rather simple and I was sure that someone has already
>> made an utility or a QGIS plugin, but all I have found yet is for R.
>> I was thinking that perhaps some of the gdaldem modes could be
>> misused for this purpose, but I believe they cannot. For QGIS I found
>> advice to use an obvious but  clumsy method of polygonising the
>> raster and finding the extremes from the vector data. And one
>> OpenJUMP developer took the challenge and wrote a prototype with Java
>> but it is not complete yet.
>> -Jukka Rahkonen-
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
> Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241030/3b693839/attachment-0001.htm>
