[gdal-dev] How to locate where the raster min and max values are?
Scott
public at postholer.com
Tue Oct 29 19:36:41 PDT 2024
It ain't pretty or efficient, but it's cheap. Here's min value. Remove
'r' from sort for max value:
gdal2xyz.py -csv -skipnodata source.tif /dev/stdout | grep -v done |
sort -rnk 3,3 -t "," | tail -1
result:
-116.9916667,36.54166667,46
On 10/29/24 17:31, Rahkonen Jukka via gdal-dev wrote:
> Hi,
> I would like to know the georeferenced coordinates of the min and max
> values of a DEM file. Even better if I could forward them into a vector
> file. If the minimum or maximum happens to be on a flat area like seabed
> I would be happy with the first pixel at the moment.
> By copy-pasting from How do I open geotiff images with GDAL in Python? -
> Stack Overflow
> <https://stackoverflow.com/questions/41996079/how-do-i-open-geotiff-images-with-gdal-in-python> and How to find the indexes of the minimum or maximum value(s) in a matrix using python ? <https://en.moonbooks.org/Articles/How-to-find-the-indexes-of-the-minimum-or-maximum-values-in-a-matrix-using-python-/> I think I managed to get the correct points as numpy indexes
>>>> import numpy as np
>>>> from osgeo import gdal
>>>> ds = gdal.Open('P3412A.tif', gdal.GA_ReadOnly)
>>>> rb = ds.GetRasterBand(1)
>>>> img_array = rb.ReadAsArray()
>>>> vmin = img_array.min()
>>>> vmax = img_array.max()
>>>> vmin
> -0.929
>>>> vmax
> 17.246
>>>> np.where(img_array==vmin)
> (array([1504], dtype=intg64), array([1189], dtype=int64))
>>>> np.where(img_array==vmax)
> (array([1545], dtype=int64), array([2423], dtype=int64))
> But now I have no idea about how to get the georeferenced coordinates.
> The task feels rather simple and I was sure that someone has already
> made an utility or a QGIS plugin, but all I have found yet is for R. I
> was thinking that perhaps some of the gdaldem modes could be misused for
> this purpose, but I believe they cannot. For QGIS I found advice to use
> an obvious but clumsy method of polygonising the raster and finding the
> extremes from the vector data. And one OpenJUMP developer took the
> challenge and wrote a prototype with Java but it is not complete yet.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
