[gdal-dev] GDAL 3.10.0 rc2 available (was Re: GDAL 3.10.0 release candidate is available)
Even Rouault
even.rouault at spatialys.com
Thu Oct 31 06:53:16 PDT 2024
Roer,
I'm afraid I can't make much sense of
https://github.com/r-spatial/sf/issues/2466 and the linked reports.
(I've never used R). Anyway to reproduce that in a more unitary way
using the C or Python GDAL API ? Or at least having stack traces of
where this segfaults ?
There was indeed a related commit in
https://github.com/OSGeo/gdal/commit/5738f7094afed715ccd44fee1865051c2b2aba2a
by the way you mention "anything changed on the GDAL side in
OGRGeometryCollection::get_GeodesicLength(),
OGRCurvePolygon::get_GeodesicLength(),
OGRLineString::get_GeodesicLength() or thereabouts?" : well, they are
*new* to 3.10.0. So you shouldn't get into those methods, unless you
explicitly call them.
Even
Le 31/10/2024 à 14:31, Roger Bivand via gdal-dev a écrit :
> I've listed four R packages depending on R package sf which show
> errors in checks with 3.10.0 rc1 and rc2, but which are clean with
> 3.9.3, tested on Fedora 40 standard GCC (both 3.9.3 and 3.10.0), GDAL
> built locally from source. The list is an sf github issue:
> https://github.com/r-spatial/sf/issues/2466.
> Two are worrying, both failing in sf CPL_area(), one at
> OGRSpatialReference::GetSemiMajor(int*) const () called from
> GetGeodesicAreaOrLength(). I'm assuming that the these failures are
> more likely to be on the sf side, but has anything changed on the GDAL
> side in OGRGeometryCollection::get_GeodesicLength(),
> OGRLineString::get_GeodesicLength() or thereabouts? Assuming any
> change was intended, the fix probably needs to be on the sf side, but
> insight would be useful.
> On the positive side, sf, terra and 1019 of their strong reverse
> dependencies (packages which cannot work without sf/terra and GDAL)
> passed without remark with 3.10.0rc1, which is good!
> Best wishes,
> Roger
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
