[gdal-dev] GDAL 3.10.0 rc2 available (was Re: GDAL 3.10.0 release candidate is available)
Roger Bivand
Roger.Bivand at nhh.no
Thu Oct 31 07:10:03 PDT 2024
On Thu, 31 Oct 2024, Even Rouault wrote:
> Roer,
> I'm afraid I can't make much sense of
> https://github.com/r-spatial/sf/issues/2466
> and the linked reports. (I've never used R). Anyway to reproduce that in a
> more unitary way using the C or Python GDAL API ? Or at least having stack
> traces of where this segfaults ?
> There was indeed a related commit in
> https://github.com/OSGeo/gdal/commit/5738f7094afed715ccd44fee1865051c2b2aba2a
> by the way you mention "anything changed on the GDAL side in
> OGRGeometryCollection::get_GeodesicLength(),
> OGRCurvePolygon::get_GeodesicLength(), OGRLineString::get_GeodesicLength() or
> thereabouts?" : well, they are *new* to 3.10.0. So you shouldn't get into
> those methods, unless you explicitly call them.
Thanks, that does help, as sf::st_area() tries to handle geodetic area in
s2 or using PostGIS code in lwgeom, before defaulting to its CPL_area at:
https://github.com/r-spatial/sf/blob/0d1a48b67d3301cd0e1dffd88e3605af630543a5/R/geom-measures.R#L37-L54
So if the geometries are geodetic, it shouldn't be reaching anything other
than planar, as in:
https://github.com/r-spatial/sf/blob/0d1a48b67d3301cd0e1dffd88e3605af630543a5/src/gdal_geom.cpp#L9-L27
should it? In https://github.com/holans/ST-COS/issues/2 there is a chunk
from a backtrace in gdb from CPL_area to
OGRGeometryCollection::get_GeodesicLength, which CPL_area didn't call
itself.
I'm fielding for Edzer here.
Roger
> Even
> Le 31/10/2024 à 14:31, Roger Bivand via gdal-dev a écrit :
>> I've listed four R packages depending on R package sf which show errors in
>> checks with 3.10.0 rc1 and rc2, but which are clean with 3.9.3, tested on
>> Fedora 40 standard GCC (both 3.9.3 and 3.10.0), GDAL built locally from
>> source. The list is an sf github issue:
>> https://github.com/r-spatial/sf/issues/2466.
>> Two are worrying, both failing in sf CPL_area(), one at
>> OGRSpatialReference::GetSemiMajor(int*) const () called from
>> GetGeodesicAreaOrLength(). I'm assuming that the these failures are more
>> likely to be on the sf side, but has anything changed on the GDAL side in
>> or thereabouts? Assuming any change was intended, the fix probably needs
>> to be on the sf side, but insight would be useful.
>> On the positive side, sf, terra and 1019 of their strong reverse
>> dependencies (packages which cannot work without sf/terra and GDAL) passed
>> without remark with 3.10.0rc1, which is good!
>> Best wishes,
>> Roger
Roger Bivand
Emeritus Professor
Department of Economics, Norwegian School of Economics,
Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway.
e-mail: Roger.Bivand at nhh.no
