[gdal-dev] GDAL 3.10.0 rc2 available (was Re: GDAL 3.10.0 release candidate is available)
Roger Bivand
Roger.Bivand at nhh.no
Thu Oct 31 13:49:04 PDT 2024
On Thu, 31 Oct 2024, Even Rouault wrote:
> By the way the logic in CPL_area is slightly incorrect. It assumes that if
> getDimension() == 2 and the type is not wkbMultiSurface or wkbMultiPolygon,
> then you can cast to OGRSurface*
> Actually this is incorrect if you have a GeometryCollection with a Polygon
> (and potentially points, lines). getDimension() will return 2 in that case,
> but it is incorrect to cast a OGRGeometryCollection* as a OGRSurface*
> I'd suggest instead something along the following (obviously untested):
> OGRwkbGeometryType gt = OGR_GT_Flatten(g[i]->getGeometryType());
> if (OGR_GT_IsSubClassOf(gt, wkbGeometryCollection)) { /* will
> match OGRMultiPolygon, OGRMultiSurface and OGRGeometryCollection */
> OGRGeometryCollection *gc = (OGRGeometryCollection *) g[i];
> out[i] = gc->get_Area();
> } else if (OGR_GT_IsSurface(gt)) {
> OGRSurface *surf = (OGRSurface *) g[i];
> out[i] = surf->get_Area();
> } else {
> out[i] = 0; // not supposed to happen, but who knows...
Even,
Thanks! Replacing lines 13-23 in sf/src/gdal_geom.cpp with the above
resolved both the segfaults in the packages using sf, and sf continued to
pass all its own checks.
The other two problems seem to be a change in handling of option strings
for a long query passed to vectortranslate (osmextract) and a missing
expected warning (sgapi), but the segfaults are I think now accounted for.
Roger
> Le 31/10/2024 à 15:40, Even Rouault via gdal-dev a écrit :
>>> should it? In
>>> https://github.com/holans/ST-COS/issues/2
>>> there is a chunk from a backtrace in gdb from CPL_area to
>>> OGRGeometryCollection::get_GeodesicLength, which CPL_area didn't call
>>> itself.
>> This is fishy. As you use the C++ API, I assume you've rebuilt the sf
>> package against the GDAL 3.10.0 headers ... ? Because currently it smells
>> like not, and some virtual method mixup. Or the stack-trace isn't reliable
>> (which might happen sometimes because of optimizations)
Roger Bivand
Emeritus Professor
Department of Economics, Norwegian School of Economics,
Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway.
e-mail: Roger.Bivand at nhh.no
