[gdal-dev] GDAL 3.10.0 rc2 available (was Re: GDAL 3.10.0 release candidate is available)
Even Rouault
even.rouault at spatialys.com
Thu Oct 31 07:55:51 PDT 2024
By the way the logic in CPL_area is slightly incorrect. It assumes that
if getDimension() == 2 and the type is not wkbMultiSurface or
wkbMultiPolygon, then you can cast to OGRSurface*
Actually this is incorrect if you have a GeometryCollection with a
Polygon (and potentially points, lines). getDimension() will return 2 in
that case, but it is incorrect to cast a OGRGeometryCollection* as a
OGRSurface*
I'd suggest instead something along the following (obviously untested):
OGRwkbGeometryType gt =
OGR_GT_Flatten(g[i]->getGeometryType());
if (OGR_GT_IsSubClassOf(gt, wkbGeometryCollection)) { /*
will match OGRMultiPolygon, OGRMultiSurface and OGRGeometryCollection */
OGRGeometryCollection *gc = (OGRGeometryCollection *) g[i];
out[i] = gc->get_Area();
} else if (OGR_GT_IsSurface(gt)) {
OGRSurface *surf = (OGRSurface *) g[i];
out[i] = surf->get_Area();
} else {
out[i] = 0; // not supposed to happen, but who knows...
Le 31/10/2024 à 15:40, Even Rouault via gdal-dev a écrit :
>> should it? In https://github.com/holans/ST-COS/issues/2 there is a
>> chunk from a backtrace in gdb from CPL_area to
>> OGRGeometryCollection::get_GeodesicLength, which CPL_area didn't call
>> itself.
> This is fishy. As you use the C++ API, I assume you've rebuilt the sf
> package against the GDAL 3.10.0 headers ... ? Because currently it
> smells like not, and some virtual method mixup. Or the stack-trace
> isn't reliable (which might happen sometimes because of optimizations)
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
