[gdal-dev] GDAL 3.10.0 rc2 available (was Re: GDAL 3.10.0 release candidate is available)
Roger Bivand
Roger.Bivand at nhh.no
Thu Oct 31 07:50:52 PDT 2024
On Thu, 31 Oct 2024, Even Rouault wrote:
>> should it? In
>> https://github.com/holans/ST-COS/issues/2
>> there is a chunk from a backtrace in gdb from CPL_area to
>> OGRGeometryCollection::get_GeodesicLength, which CPL_area didn't call
>> itself.
> This is fishy. As you use the C++ API, I assume you've rebuilt the sf package
> against the GDAL 3.10.0 headers ... ? Because currently it smells like not,
> and some virtual method mixup. Or the stack-trace isn't reliable (which might
> happen sometimes because of optimizations)
This is Norway, we are fishy by definition. Yes, sf fully re-installed
(configure uses gdal-config, headers for rc2 installed 13:37 CEST), sf
installed 14:04 CEST.
Roger
Roger Bivand
Emeritus Professor
Department of Economics, Norwegian School of Economics,
Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway.
e-mail: Roger.Bivand at nhh.no
