[gdal-dev] STACIT driver and iten collections and origin / pixel size
Even Rouault
even.rouault at spatialys.com
Wed Sep 11 07:11:33 PDT 2024
Michael,
can you paste the definition of such STAC Json item ? Guess:
"proj:epsg" is present, but "proj:bbox" or "proj:transform" are using
WGS84 coordinates ?
Even
Le 11/09/2024 à 15:59, Michael Smith via gdal-dev a écrit :
> Using gdal 3.9.2:
> I’m using pystac to create stac json item collections. I’m setting the
> srs of using the projection extension and gdalinfo returns the correct
> srs that I am setting.
> gdalinfo STACIT:13459.json
> Driver: VRT/Virtual Raster
> Files:
> /vsicurl/https://noaa-nos-coastal-lidar-pds.s3.us-east-1.amazonaws.com/dem/WA_King_DEM_2016_8589/./kingcounty_delivery4_block2_be.tif
> /vsicurl/https://noaa-nos-coastal-lidar-pds.s3.us-east-1.amazonaws.com/dem/WA_King_DEM_2016_8589/./kingcounty_delivery4_block1_be.tif
> Size is 74182, 79467
> Coordinate System is:
> COMPOUNDCRS["NAD83(HARN) / Washington North (ftUS) + NAVD88 height
> (ftUS)",
> PROJCRS["NAD83(HARN) / Washington North (ftUS)",
> But when I look at the origin / pixel size / bounding box, its in
> geodetic coordinates. Is this how it should be reported? I was also
> doing some conversions from stac to vrt to support arcpro users and
> the vrt then inherits the bbox/pixel size/origin of the geodetic
> values from stac. Trying to see how I can get these values in actual
> projected coordinates.
> Mike
> Michael Smith
> Remote Sensing/GIS Center
> US Army Corps of Engineers
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240911/b145e478/attachment.htm>
