[gdal-dev] STACIT driver and iten collections and origin / pixel size
Michael Smith michael.smith.erdc at gmail.com
Wed Sep 11 07:17:04 PDT 2024
The proj:bbox is in geodetic. Is that the issue, the bbox needs to be in the projected coords? I have proj:projjson and proj:wkt2 defined but the bbox is geodetic.
Mike
Date: Wednesday, September 11, 2024 at 9:11 AM
To: Michael Smith <michael.smith.erdc at gmail.com>, <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] STACIT driver and iten collections and origin / pixel size
Michael,
can you paste the definition of such STAC Json item ?  Guess: "proj:epsg" is present, but "proj:bbox" or "proj:transform" are using WGS84 coordinates ?
Even
Le 11/09/2024 à 15:59, Michael Smith via gdal-dev a écrit :
Using gdal 3.9.2:
I’m using pystac to create stac json item collections. I’m setting the srs of using the projection extension and gdalinfo returns the correct srs that I am setting.
gdalinfo STACIT:13459.json
Driver: VRT/Virtual Raster
Files: /vsicurl/https://noaa-nos-coastal-lidar-pds.s3.us-east-1.amazonaws.com/dem/WA_King_DEM_2016_8589/./kingcounty_delivery4_block2_be.tif
       /vsicurl/https://noaa-nos-coastal-lidar-pds.s3.us-east-1.amazonaws.com/dem/WA_King_DEM_2016_8589/./kingcounty_delivery4_block1_be.tif
Size is 74182, 79467
Coordinate System is:
COMPOUNDCRS["NAD83(HARN) / Washington North (ftUS) + NAVD88 height (ftUS)",
    PROJCRS["NAD83(HARN) / Washington North (ftUS)",
But when I look at the origin / pixel size / bounding box, its in geodetic coordinates. Is this how it should be reported? I was also doing some conversions from stac to vrt to support arcpro users and the vrt then inherits the bbox/pixel size/origin of the geodetic values from stac. Trying to see how I can get these values in actual projected coordinates.
Mike
Michael Smith
Remote Sensing/GIS Center
US Army Corps of Engineers
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240911/9b4eef6d/attachment.htm>
