[gdal-dev] STACIT driver and iten collections and origin / pixel size
Even Rouault
even.rouault at spatialys.com
Wed Sep 11 07:19:03 PDT 2024
Le 11/09/2024 à 16:17, Michael Smith a écrit :
> The proj:bbox is in geodetic. Is that the issue, the bbox needs to be
> in the projected coords? I have proj:projjson and proj:wkt2 defined
> but the bbox is geodetic.
Per the spec, yes, this is wrong.
Cf
https://github.com/stac-extensions/projection/?tab=readme-ov-file#projbbox:
"Bounding box of the assets represented by this Item in the asset data
CRS. Specified as 4 or 6 coordinates based on the CRS defined in the
|proj:code|, |proj:projjson| or |proj:wkt2| fields. [...]"
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240911/8bfd995f/attachment-0001.htm>
