[gdal-dev] Motion: approve RFC 101 "Raster dataset read-only thread-safety"
Javier Jimenez Shaw j1 at jimenezshaw.com
Thu Sep 12 07:27:39 PDT 2024
+1 Javier
On Thu, 12 Sept 2024 at 08:27, Rahkonen Jukka via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> +1
> -Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Even
> Rouault via gdal-dev
> Lähetetty: keskiviikko 11. syyskuuta 2024 22.27
> Vastaanottaja: gdal-dev at lists.osgeo.org
> Aihe: [gdal-dev] Motion: approve RFC 101 "Raster dataset read-only
> thread-safety"
> Hi,
> I move to approve RFC 101 "Raster dataset read-only thread-safety":
> https://github.com/OSGeo/gdal/pull/10676
> Starting with my +1,
> The candidate implementation is available in
> https://github.com/OSGeo/gdal/pull/10746. While fine tuning it, I
> realized there were subtleties, related to the fact we use thread-local
> datasets under the hood, for methods returning a non-"primitive" type, such
> as a "const char*" whose lifetime is tied to a dataset/band. If we'd get it
> from a thread-local dataset, and that one would be later evicted from the
> cache (not very common, but could happen if one would open tons of
> thread-safe datasets at the same time), then you could have use-after-free
> issues. For such methods (GetMetadata(), GetMetadataItem(),
> GetProjectionRef(), etc. as well as GetColorTable() which returns a
> GDALColorTable pointer, or GetSpatialRef() which returns a
> OGRSpatialReference*), I've preferred to protect their access with a mutex
> around the "prototype" dataset passed when constructing
> GDALMultiThreadedDataset, whose lifetime is at least as long as
> GDALMultiThreadedDataset (cf commit
> https://github.com/OSGeo/gdal/pull/10746/commits/849e9cea711efd30c47fd90a7a6b71a75611c1a5#diff-687008dd6e3d5ac8ad05568272746ed75b84de50bde508f78f2d79a6842825c7L428
> . Normally such methods aren't called in user code repeatedly, so there
> should be any noticeable lock contention in practice. The main objective of
> the RFC which is to be able to issue RasterIO() requests in parallel isn't
> affected by that. Ah, and one thing I realized is that OGRSpatialReference
> isn't thread-safe, so I've also added an optional
> SetThreadSafe() on it, to also use a per-instance mutex in multi-threaded
> scenarios (cf commit
> https://github.com/OSGeo/gdal/pull/10746/commits/c7e1862273dd018e58a01f25b21fdff6dbfdd1cd
> Multi-threading is hard...
> Even
> http://www.spatialys.com/
> My software is free, but my time generally not.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240912/0c04d012/attachment.htm>
