[gdal-dev] Motion: approve RFC 101 "Raster dataset read-only thread-safety"
Even Rouault
even.rouault at spatialys.com
Thu Sep 19 13:53:07 PDT 2024
Motion passed with +1 from PSC members KurtS, JukkaR, JavierJS and me.
Le 11/09/2024 à 21:26, Even Rouault via gdal-dev a écrit :
> Hi,
> I move to approve RFC 101 "Raster dataset read-only thread-safety":
> https://github.com/OSGeo/gdal/pull/10676
> Starting with my +1,
> The candidate implementation is available in
> https://github.com/OSGeo/gdal/pull/10746. While fine tuning it, I
> realized there were subtleties, related to the fact we use
> thread-local datasets under the hood, for methods returning a
> non-"primitive" type, such as a "const char*" whose lifetime is tied
> to a dataset/band. If we'd get it from a thread-local dataset, and
> that one would be later evicted from the cache (not very common, but
> could happen if one would open tons of thread-safe datasets at the
> same time), then you could have use-after-free issues. For such
> methods (GetMetadata(), GetMetadataItem(), GetProjectionRef(), etc. as
> well as GetColorTable() which returns a GDALColorTable pointer, or
> GetSpatialRef() which returns a OGRSpatialReference*), I've preferred
> to protect their access with a mutex around the "prototype" dataset
> passed when constructing GDALMultiThreadedDataset, whose lifetime is
> at least as long as GDALMultiThreadedDataset (cf commit
> https://github.com/OSGeo/gdal/pull/10746/commits/849e9cea711efd30c47fd90a7a6b71a75611c1a5#diff-687008dd6e3d5ac8ad05568272746ed75b84de50bde508f78f2d79a6842825c7L428)
> . Normally such methods aren't called in user code repeatedly, so
> there should be any noticeable lock contention in practice. The main
> objective of the RFC which is to be able to issue RasterIO() requests
> in parallel isn't affected by that. Ah, and one thing I realized is
> that OGRSpatialReference isn't thread-safe, so I've also added an
> optional SetThreadSafe() on it, to also use a per-instance mutex in
> multi-threaded scenarios (cf commit
> https://github.com/OSGeo/gdal/pull/10746/commits/c7e1862273dd018e58a01f25b21fdff6dbfdd1cd).
> Multi-threading is hard...
> Even
http://www.spatialys.com
