[gdal-dev] [ERROR]GDAL 3.8.4 on Ubuntu 24.04 could not warp after minutes, but GDAL 3.4.1 on Ubuntu 22.04 can?
Huu Bang Pham
bphamhuu at constructor.university
Tue Sep 17 07:37:16 PDT 2024
This is a test case and it works fine on Ubuntu 22.04. I'm not sure why
in Ubuntu 24.04 it stops working and hangs up.
On 17.09.24 4:27 PM, Rahkonen Jukka wrote:
> You don't often get email from jukka.rahkonen at maanmittauslaitos.fi.
> Learn why this is important
> <https://aka.ms/LearnAboutSenderIdentification>
> Hi,
> Out of curiosity, the source file contains one single pixel. Is there
> a real use case, or are you just experimenting?
> -Jukka Rahkonen-
> *Lähettäjä:*gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta *Huu
> Bang Pham via gdal-dev
> *Lähetetty:* tiistai 17. syyskuuta 2024 17.18
> *Vastaanottaja:* gdal-dev at lists.osgeo.org
> *Aihe:* [gdal-dev] [ERROR]GDAL 3.8.4 on Ubuntu 24.04 could not warp
> Hello,
> I'm testing *GDAL 3.8.4, released 2024/02/08 on Ubuntu 24.04* and it
> has a strange issue.
> I have a VRT file which *can be projected by gdalwarp on Ubuntu 22.04
> (GDAL 3.4.1, released 2021/12/27) in less than one second*, but *on
> Ubuntu 24.04, gdalwarp is stuck even after minutes *for no reason.
> The VRT file and the dummy PNG file for it are attached in the
> attachment files.
> gdalwarp command which I used is:
> gdalwarp test.vrt -t_srs EPSG:32631 -tap -tr 1000 1000 -of VRT
> output.vrt -overwrite
> gdalinfo of *test.vrt *is:
> Driver: VRT/Virtual Raster
> Files: test.vrt
> /tmp/dummy_file_for_gdal.vrt.png
> Size is 1, 1
> Coordinate System is:
> GEOGCRS["WGS 84",
> DATUM["World Geodetic System 1984",
> ELLIPSOID["WGS 84",6378137,298.257223563,
> LENGTHUNIT["metre",1]]],
> PRIMEM["Greenwich",0,
> ANGLEUNIT["degree",0.0174532925199433]],
> CS[ellipsoidal,2],
> AXIS["geodetic latitude (Lat)",north,
> ORDER[1],
> AXIS["geodetic longitude (Lon)",east,
> ORDER[2],
> ID["EPSG",4326]]
> Data axis to CRS axis mapping: 2,1
> Origin = (6.868800000000000,51.374699999999997)
> Pixel Size = (0.000900000000000,-0.000900000000000)
> Corner Coordinates:
> Upper Left ( 6.8688000, 51.3747000) ( 6d52' 7.68"E,
> 51d22'28.92"N)
> Lower Left ( 6.8688000, 51.3738000) ( 6d52' 7.68"E,
> 51d22'25.68"N)
> Upper Right ( 6.8697000, 51.3747000) ( 6d52'10.92"E,
> 51d22'28.92"N)
> Lower Right ( 6.8697000, 51.3738000) ( 6d52'10.92"E,
> 51d22'25.68"N)
> Center ( 6.8692500, 51.3742500) ( 6d52' 9.30"E,
> 51d22'27.30"N)
> Band 1 Block=1x1 Type=Byte, ColorInterp=Red
> gdalinfo of*/tmp/dummy_file_for_gdal.vrt.png* is:
> Driver: PNG/Portable Network Graphics
> Files: /tmp/dummy_file_for_gdal.vrt.png
> Size is 1, 1
> Image Structure Metadata:
> INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left ( 0.0, 0.0)
> Lower Left ( 0.0, 1.0)
> Upper Right ( 1.0, 0.0)
> Lower Right ( 1.0, 1.0)
> Center ( 0.5, 0.5)
> Band 2 Block=1x1 Type=Byte, ColorInterp=Green
> Band 3 Block=1x1 Type=Byte, ColorInterp=Blue
> Thanks,
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240917/5be51589/attachment-0001.htm>
