[gdal-dev] [ERROR]GDAL 3.8.4 on Ubuntu 24.04 could not warp after minutes, but GDAL 3.4.1 on Ubuntu 22.04 can?
Even Rouault
even.rouault at spatialys.com
Tue Sep 17 08:03:19 PDT 2024
bug confirmed. Fix in https://github.com/OSGeo/gdal/pull/10822
Even
Le 17/09/2024 à 16:18, Huu Bang Pham via gdal-dev a écrit :
> Hello,
> I'm testing *GDAL 3.8.4, released 2024/02/08 on Ubuntu 24.04* and it
> has a strange issue.
> I have a VRT file which *can be projected by gdalwarp on Ubuntu 22.04
> (GDAL 3.4.1, released 2021/12/27) in less than one second*, but *on
> Ubuntu 24.04, gdalwarp is stuck even after minutes *for no reason.
> The VRT file and the dummy PNG file for it are attached in the
> attachment files.
> gdalwarp command which I used is:
>> gdalwarp test.vrt -t_srs EPSG:32631 -tap -tr 1000 1000 -of VRT
>> output.vrt -overwrite
> gdalinfo of *test.vrt *is:
>> Driver: VRT/Virtual Raster
>> Files: test.vrt
>> /tmp/dummy_file_for_gdal.vrt.png
>> Size is 1, 1
>> Coordinate System is:
>> GEOGCRS["WGS 84",
>> DATUM["World Geodetic System 1984",
>> ELLIPSOID["WGS 84",6378137,298.257223563,
>> LENGTHUNIT["metre",1]]],
>> PRIMEM["Greenwich",0,
>> ANGLEUNIT["degree",0.0174532925199433]],
>> CS[ellipsoidal,2],
>> AXIS["geodetic latitude (Lat)",north,
>> ORDER[1],
>> AXIS["geodetic longitude (Lon)",east,
>> ORDER[2],
>> ID["EPSG",4326]]
>> Data axis to CRS axis mapping: 2,1
>> Origin = (6.868800000000000,51.374699999999997)
>> Pixel Size = (0.000900000000000,-0.000900000000000)
>> Corner Coordinates:
>> Upper Left ( 6.8688000, 51.3747000) ( 6d52' 7.68"E, 51d22'28.92"N)
>> Lower Left ( 6.8688000, 51.3738000) ( 6d52' 7.68"E, 51d22'25.68"N)
>> Upper Right ( 6.8697000, 51.3747000) ( 6d52'10.92"E, 51d22'28.92"N)
>> Lower Right ( 6.8697000, 51.3738000) ( 6d52'10.92"E, 51d22'25.68"N)
>> Center ( 6.8692500, 51.3742500) ( 6d52' 9.30"E, 51d22'27.30"N)
>> Band 1 Block=1x1 Type=Byte, ColorInterp=Red
> gdalinfo of*/tmp/dummy_file_for_gdal.vrt.png* is:
>> Driver: PNG/Portable Network Graphics
>> Files: /tmp/dummy_file_for_gdal.vrt.png
>> Size is 1, 1
>> Image Structure Metadata:
>> INTERLEAVE=PIXEL
>> Corner Coordinates:
>> Upper Left ( 0.0, 0.0)
>> Lower Left ( 0.0, 1.0)
>> Upper Right ( 1.0, 0.0)
>> Lower Right ( 1.0, 1.0)
>> Center ( 0.5, 0.5)
>> Band 2 Block=1x1 Type=Byte, ColorInterp=Green
>> Band 3 Block=1x1 Type=Byte, ColorInterp=Blue
> Thanks,
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240917/4f3aad46/attachment.htm>
