[gdal-dev] [ERROR]GDAL 3.8.4 on Ubuntu 24.04 could not warp after minutes, but GDAL 3.4.1 on Ubuntu 22.04 can?
Huu Bang Pham bphamhuu at constructor.university
Tue Sep 17 08:08:20 PDT 2024
Hi Rouault,
Thanks for your quick reply. However, I'm stuck with GDAL 3.8.4 on
Ubuntu 24.04.
Do you have any suggestion / workaround for this issue, in stead of
building latest gdal with your fix manually?
Thanks,
On 17.09.24 5:03 PM, Even Rouault wrote:
> Hi,
> bug confirmed. Fix in https://github.com/OSGeo/gdal/pull/10822
> Even
> Le 17/09/2024 à 16:18, Huu Bang Pham via gdal-dev a écrit :
>> Hello,
>> I'm testing *GDAL 3.8.4, released 2024/02/08 on Ubuntu 24.04* and it
>> has a strange issue.
>> I have a VRT file which *can be projected by gdalwarp on Ubuntu 22.04
>> (GDAL 3.4.1, released 2021/12/27) in less than one second*, but *on
>> Ubuntu 24.04, gdalwarp is stuck even after minutes *for no reason.
>> The VRT file and the dummy PNG file for it are attached in the
>> attachment files.
>> gdalwarp command which I used is:
>>> gdalwarp test.vrt -t_srs EPSG:32631 -tap -tr 1000 1000 -of VRT
>>> output.vrt -overwrite
>> gdalinfo of *test.vrt *is:
>>> Driver: VRT/Virtual Raster
>>> Files: test.vrt
>>>        /tmp/dummy_file_for_gdal.vrt.png
>>> Size is 1, 1
>>> Coordinate System is:
>>> GEOGCRS["WGS 84",
>>>     DATUM["World Geodetic System 1984",
>>>         ELLIPSOID["WGS 84",6378137,298.257223563,
>>>             LENGTHUNIT["metre",1]]],
>>>     PRIMEM["Greenwich",0,
>>>         ANGLEUNIT["degree",0.0174532925199433]],
>>>     CS[ellipsoidal,2],
>>>         AXIS["geodetic latitude (Lat)",north,
>>>             ORDER[1],
>>>         AXIS["geodetic longitude (Lon)",east,
>>>             ORDER[2],
>>>     ID["EPSG",4326]]
>>> Data axis to CRS axis mapping: 2,1
>>> Origin = (6.868800000000000,51.374699999999997)
>>> Pixel Size = (0.000900000000000,-0.000900000000000)
>>> Corner Coordinates:
>>> Upper Left  (   6.8688000,  51.3747000) (  6d52' 7.68"E, 51d22'28.92"N)
>>> Lower Left  (   6.8688000,  51.3738000) (  6d52' 7.68"E, 51d22'25.68"N)
>>> Upper Right (   6.8697000,  51.3747000) (  6d52'10.92"E, 51d22'28.92"N)
>>> Lower Right (   6.8697000,  51.3738000) (  6d52'10.92"E, 51d22'25.68"N)
>>> Center      (   6.8692500,  51.3742500) (  6d52' 9.30"E, 51d22'27.30"N)
>>> Band 1 Block=1x1 Type=Byte, ColorInterp=Red
>> gdalinfo of*/tmp/dummy_file_for_gdal.vrt.png* is:
>>> Driver: PNG/Portable Network Graphics
>>> Files: /tmp/dummy_file_for_gdal.vrt.png
>>> Size is 1, 1
>>> Image Structure Metadata:
>>>   INTERLEAVE=PIXEL
>>> Corner Coordinates:
>>> Upper Left  (    0.0,    0.0)
>>> Lower Left  (    0.0,    1.0)
>>> Upper Right (    1.0,    0.0)
>>> Lower Right (    1.0,    1.0)
>>> Center      (    0.5,    0.5)
>>> Band 2 Block=1x1 Type=Byte, ColorInterp=Green
>>> Band 3 Block=1x1 Type=Byte, ColorInterp=Blue
>> Thanks,
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com/
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240917/010d1c63/attachment.htm>
